Re: New print surface material? November 15, 2015 12:45PM |
Re: New print surface material? November 15, 2015 02:18PM |
Re: New print surface material? November 18, 2015 01:45AM |
Re: New print surface material? November 19, 2015 06:01AM |
Re: New print surface material? November 19, 2015 08:30AM |
Re: New print surface material? November 22, 2015 06:10PM |
Re: New print surface material? November 24, 2015 03:46AM |
Re: New print surface material? November 26, 2015 01:42AM |
Mutley3D
elwood127
You know, you could add tape to order. That way we don't have 30 feet sitting around for years to come.
PrintBite is cheap and no frills but very effective. That is what people wish for, cheap, no frills, and effective. You could use 3M 468P tape, buy a sheet at greater expense and have none spare.
Re: New print surface material? November 26, 2015 06:58PM |
Re: New print surface material? November 28, 2015 02:10PM |
Re: New print surface material? November 28, 2015 11:21PM |
Re: New print surface material? November 29, 2015 01:05PM |
ElmoC
Been doing some PLA printing with this material and having some bad lifting in spots. 90% of the print sticks fine, but there are several areas where the print doesn't stick and curls up. I have seen similar problems with PETG, but not as bad. Any suggestions? I really want to keep using it, but might have to switch back to BuildTak so I can get some print jobs finished.
Re: New print surface material? November 29, 2015 01:24PM |
Re: New print surface material? November 30, 2015 03:55PM |
Re: New print surface material? November 30, 2015 05:27PM |
DjDemonD
Any suggestion for the best type of tape available in the UK for attaching this surface to my aluminium bed? I am very happy with the printbite but the cheapo tape I used is not standing up to abs heat bed temperatures.
Re: New print surface material? November 30, 2015 05:32PM |
ElmoC
After posting, I discovered the nozzle temp had gotten set way too low so reprinted with higher. This is eSun White PLA. Was 185, now 200. Bed temp was set to 70 (normally was 60). I reprinted and still got lifting, but not as bad. Had been cleaning with 95% isopropyl Alcohol. Just did a cleaning wih Acetone and getting ready to print again. Will clean with glass cleaner if still having problems. After that, will start raising nozzle temp more.
Re: New print surface material? December 01, 2015 12:27AM |
Re: New print surface material? December 01, 2015 12:53AM |
Treito
However regarding ABS I am not able to get a very good stick. It seems like my fan is the right choice for PLA printing but it may be too strong for ABS and ABS does not stick very well.
Re: New print surface material? December 01, 2015 05:12AM |
Re: New print surface material? December 01, 2015 11:08PM |
DaveOB
As far as I know, and from all the ABS printing I have done, you should not have a fan blowing on the print for ABS.
Re: New print surface material? December 02, 2015 02:48AM |
Re: New print surface material? December 02, 2015 09:05PM |
Re: New print surface material? December 05, 2015 03:53AM |
Re: New print surface material? December 05, 2015 05:07AM |
Re: New print surface material? December 05, 2015 05:33AM |
Re: New print surface material? December 05, 2015 05:37AM |
Re: New print surface material? December 05, 2015 05:42AM |
Re: New print surface material? December 05, 2015 08:04AM |
Re: New print surface material? December 05, 2015 09:42AM |
