Re: New print surface material? February 10, 2016 06:17PM |
Re: New print surface material? February 10, 2016 06:27PM |
dc42
DjDemonD
Any suggestion for the best type of tape available in the UK for attaching this surface to my aluminium bed? I am very happy with the printbite but the cheapo tape I used is not standing up to abs heat bed temperatures.
3M 8153LE may be a good choice. Look for it on Amazon or eBay.
Re: New print surface material? February 10, 2016 07:01PM |
Re: New print surface material? February 10, 2016 07:08PM |
Re: New print surface material? February 11, 2016 04:51PM |
Re: New print surface material? February 11, 2016 06:31PM |
Re: New print surface material? February 26, 2016 02:59PM |
Re: New print surface material? February 27, 2016 09:29AM |
PETG does not need printbite. It will adhere to the bed of glass without anything. Matter of fact. I was having issues with it grabbing glass too well. My bed setting was 87 deg plain glass. The print stuck so well it took off some of the glass when I took it off. Now I know that I have to have the bed a little cooler. And I have to adjust my z height.Quote
Zedsquared
Just reporting on on my printbite experience with PETG, again no real problems. I run the bed at 70C and it grips fine, the only difference it it doesn't release quite as completely as ABS and PLA seem to when the bed has cooled. It's still easy to remove the part though.
I ran the bed at 110C with PETG once (accidentally used an ABS gcode file) and that was solidly stuck on until the bed had cooled right down to ambient (20C) whereas prints run at 70C were removable once the bed was at about 40C.
Cheers,
Robin.
Re: New print surface material? February 27, 2016 10:23AM |
Re: New print surface material? February 28, 2016 08:25PM |
Re: New print surface material? March 03, 2016 03:17PM |
Re: New print surface material? March 03, 2016 03:30PM |
Re: New print surface material? March 03, 2016 06:13PM |
evenbor
have printbite, but cant get mine print to stick. Have tried to adjust hight, and clean with aceton. So went back to buildtak. For me this is overpriced garbage
Re: New print surface material? March 03, 2016 07:22PM |
evenbor
I have printbite, but cant get mine print to stick. Have tried to adjust hight, and clean with aceton. So went back to buildtak. For me this is overpriced garbage
Re: New print surface material? March 10, 2016 06:04AM |
Got my ordered printbite this week. ThanksQuote
Mutley3D
PrintBite now supplied with adhesive tape attached, peel and stick. No cost increase either!
Re: New print surface material? March 11, 2016 08:13PM |
Re: New print surface material? March 23, 2016 03:23PM |
Re: New print surface material? March 23, 2016 03:59PM |
Re: New print surface material? March 23, 2016 04:47PM |
Re: New print surface material? March 24, 2016 01:39AM |
Re: New print surface material? March 25, 2016 02:00PM |
Re: New print surface material? March 25, 2016 09:19PM |
Re: New print surface material? March 26, 2016 08:14AM |
Re: New print surface material? March 26, 2016 08:58AM |
Re: New print surface material? March 28, 2016 09:57PM |
Re: New print surface material? March 29, 2016 12:34AM |
Re: New print surface material? March 29, 2016 02:55AM |
PRZ
I have questions about adhesion of some products.
I have adhesion difficulties with 'silver' PLA (esun brand), which have very low adhesion and need much higher temperature than other PLA. I assume it contains aluminium. Someone tested it on this surface ?
Surprinsingly, I got slightly better result with 'silver' ABS (reprapper brand), while not super adhesive. Again, someone tested it ?
And something very special, but I am quite interested to try for mechanical parts, this is POM. This stuff is used for gears and bearings and does not adhere to anything, so printing it is reputed difficult (need plates with holes).
Tested on printbite ?
Re: New print surface material? March 29, 2016 05:54AM |
Re: New print surface material? March 29, 2016 07:03AM |
PRZ
Re: New print surface material? March 29, 2016 08:51AM |
