Re: New print surface material? August 20, 2016 03:51AM |
Re: New print surface material? August 22, 2016 01:58AM |
Re: New print surface material? August 22, 2016 03:42PM |
Phytone
After going through PLA, ABS and PETG with great results - I'm trying Nylon (3DPrima Nylon)
Have cooked the Nylon for 10 hours in the oven to make sure it is dry, but every time the print gets more than 0.8mm thick, the darn thing lifts off the bed.
Have cleaned with Acetone - nope
Have put down a coat of hairspray - nope
Have put down a coat of PVA/water - nope
Have played around with nozzle heights, from well and truly squished to a nice bead - nope
Bed Temperatures between 70 - 100 deg - nope
Extruder temp is 250 and it comes out nice.
So can anyone share their setup for Print Bite and Nylon?
Thanks in advance!
Kevin
Re: New print surface material? August 23, 2016 07:05AM |
Re: New print surface material? October 27, 2016 06:32PM |
Re: New print surface material? October 27, 2016 07:16PM |
hobbymods
Hi Mutley,
I made an inquiry through your website some time back, regarding getting a couple of your Printbite sheets cut to 240x240mm and posted to Australia.
No reply at this stage....can it be done?
Re: New print surface material? October 27, 2016 08:18PM |
hobbymods
hobbymods
Hi Mutley,
Here I am again....I sent another email a few days back just asking it the items have been dispatched (after this first post here you contacted me and said it was in hand) and if I could get a tracking number.
I really hate to nag, but it's been a while and the communication is sparse.
Could you please let me know where we're at, and send me a tracking number?
Thank you
Re: New print surface material? October 28, 2016 12:18AM |
Re: New print surface material? November 05, 2016 05:53AM |
Mutley3D
I will PM you to resolve this urgently. Did you email the old mutley3d.com or new flex3drive.com domain?
hobbymods
hobbymods
Hi Mutley,
Thank you
Re: New print surface material? November 29, 2016 04:44AM |
Re: New print surface material? December 02, 2016 12:48PM |
Re: New print surface material? December 02, 2016 09:46PM |
Re: New print surface material? December 02, 2016 10:37PM |
Re: New print surface material? December 03, 2016 04:27PM |
Re: New print surface material? December 05, 2016 06:27PM |
Re: New print surface material? December 07, 2016 04:41PM |
Re: New print surface material? December 08, 2016 01:10PM |
Re: New print surface material? December 08, 2016 02:56PM |
Re: New print surface material? December 12, 2016 10:41AM |
Re: New print surface material? December 13, 2016 04:58AM |
UnicronNL
@stephi
I use PC from hobbyking, print-bed 170c and nozzle 315c, no warping problems with these temps
(my printbite is slowly turning brownish )
Re: New print surface material? December 13, 2016 07:19AM |
GRAYWOLF
I use ABS print-bed 100c and nozzle 240c get temp related adhesion issues (cold air blowing trough room)
Mine is turning brown
I am wondering about removing the glass and putting the bite directly to the aluminium heatbed.
Re: New print surface material? December 13, 2016 07:25AM |
Re: New print surface material? January 20, 2017 10:26PM |
Re: New print surface material? January 20, 2017 11:59PM |
animoose
Has anyone had luck with nGen on PrintBite? I haven't found settings that work well. It does stick, but not very firmly, and so print sometimes end up peeling away from the print bed after a while. I am using 220C on a bed at 80C, but have varied both values up and down from this.
Re: New print surface material? January 21, 2017 12:13AM |
Re: New print surface material? January 21, 2017 07:07AM |
Re: New print surface material? January 28, 2017 10:42PM |
Origamib
I've found good results for nGen with 90c first layer, then 80. Nozzle temps at 250/230c. Cooling fan should be as low as possible as nGen does warp a little, especially on larger pieces.
Re: New print surface material? January 31, 2017 05:22AM |
Re: New print surface material? January 31, 2017 07:04AM |
Re: New print surface material? January 31, 2017 08:00AM |
