Re: New print surface material? March 27, 2017 09:26AM |
Re: New print surface material? March 27, 2017 10:15AM |
Re: New print surface material? April 09, 2017 05:51PM |
Re: New print surface material? April 09, 2017 07:53PM |
Re: New print surface material? May 20, 2017 08:23AM |
Re: New print surface material? May 25, 2017 06:29AM |
Re: New print surface material? May 25, 2017 08:10AM |
Re: New print surface material? August 23, 2017 04:11AM |
gadgetmind
I've got some transparent PLA that needs 230C to stick to PrintBite and some other PLA that's fine at 200C. More bed temperature also helps, but once past 65C I start seeing corner curling.
Yes, height is critical and I now have my own level test that's 9 discs with holes in them printed in a 3x3 grid and only one layer thick. This lets me quickly check and tweak level and then I use my adjustable z stop to drop the nozzle down until every bit of detail sticks firm from the start despite the speed and the bottom layer looks good.
Re: New print surface material? August 23, 2017 04:27AM |
Re: New print surface material? August 23, 2017 04:35AM |
Anna & Karl
The question is: Print Bite is durable, but does it wear off after time? Would too many wipes with acetone or the high temperatures of printing ABS damage it? Does it acumulate dirt or dust?
Re: New print surface material? August 23, 2017 04:37AM |
Re: New print surface material? August 23, 2017 06:35AM |
Re: New print surface material? August 23, 2017 06:58AM |
Re: New print surface material? August 23, 2017 07:49AM |
Re: New print surface material? August 24, 2017 08:48AM |
Re: New print surface material? August 24, 2017 09:36AM |
Re: New print surface material? September 02, 2017 04:39PM |
Re: New print surface material? September 07, 2017 03:21AM |
Re: New print surface material? September 07, 2017 03:59AM |
Re: New print surface material? September 07, 2017 04:53AM |
Re: New print surface material? September 10, 2017 07:08AM |
Re: New print surface material? September 10, 2017 07:13AM |
Re: New print surface material? September 10, 2017 10:22AM |
Re: New print surface material? September 13, 2017 10:51AM |
Re: New print surface material? December 15, 2017 03:49PM |
Re: New print surface material? December 15, 2017 05:38PM |
Re: New print surface material? December 15, 2017 05:55PM |
Re: New print surface material? December 16, 2017 01:22AM |
Re: New print surface material? December 16, 2017 04:16AM |
Re: New print surface material? December 16, 2017 05:54AM |
