Connecting to the Duet via Putty
October 20, 2015 03:30PM
I have been building a reprappro Huxley Duo and wanted to connect to it via USB serial from my Linux pc using the Putty terminal program.
I had no problem connecting via the Arduino IDE Serial monitor, but witht he same config on Putty I get no response, until after a lot of gcode typing, I get a message the gcode buffer is full.
Does anyone have any ideas how to debug this or know of a Putty config that works?
Thanks,
Bob
Re: Connecting to the Duet via Putty
October 20, 2015 04:21PM
Sounds like putty may be sending the wrong line end character to me. Can you configure putty to send CR+LF at the end of a line? Although I think RepRapFirmware is happy with just LF.
October 20, 2015 04:48PM
Thanks for the suggestion.
I tried sending CR, then LF, the CR+LF, end even no line end, but nothing had any effect. I did some tests with an Arduino, and putty does indeed send what it is suposed to send, so I am at a loss. I have used Putty a zillion times in many configurations so I really doubt that Putty itself could be the problem.
I can't understand what is wrong.
Cheers,
Bob
October 20, 2015 04:54PM
Are you sending the command characters in upper case, and have you made sure that putty is not adding a parity bit?
October 20, 2015 05:17PM
Hello again!
Yes, all commands are upper case, and there is no parity bit.
Thanks for the help, but I can't figure it out.
Cheers,
Bob
October 20, 2015 05:27PM
Maybe I'll try it when I get time, but it will be the Windows version.
