Software on (Arch-)Linux
Posted by 4dPrinter
October 29, 2015 12:37PM
Hi
I built my first 3d printer. An i3 prusa. It seems to work! Woohoo!
On Archlinux, I use printrun to move the printhead around and as far as I can tell, this works like a charm. If I understood correctly, I now need a slic3r to actually print something. When I try to start slic3r from printrun (pronterface), it tells me
python: can't open file 'skeinforge/skeinforge_application/skeinforge.py': [Errno 2] No such file or directory
I think this is an old setting and I probably just need to change the path that's invoked in the options menu. However, I first tried to run slic3r without printrun. I have a config file for slic3r from here. So I try to start slic3r with
x@y: ~/Downloads/3dPrinter $ slic3r --load default_config_05mm_pla.ini --gui
Warning: Mismatch between the program and library build versions detected.
The library used 2.8 (no debug,Unicode,compiler with C++ ABI 1008,wx containers,compatible with 2.6),
and your program used 2.8 (no debug,Unicode,compiler with C++ ABI 1009,wx containers,compatible with 2.6).
Base class package "Wx::GLCanvas" is empty.
    (Perhaps you need to 'use' the module which defines that package first,
    or make that module available in @INC (@INC contains: /usr/bin/vendor_perl/lib /usr/lib/perl5/site_perl /usr/share/perl5/site_perl /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5/core_perl /usr/share/perl5/core_perl .).
 at /usr/share/perl5/vendor_perl/Slic3r/GUI/Plater/2DToolpaths.pm line 121.
BEGIN failed--compilation aborted at /usr/share/perl5/vendor_perl/Slic3r/GUI/Plater/2DToolpaths.pm line 121.
Compilation failed in require at /usr/share/perl5/vendor_perl/Slic3r/GUI.pm line 16.
BEGIN failed--compilation aborted at /usr/share/perl5/vendor_perl/Slic3r/GUI.pm line 16.
Compilation failed in require at (eval 66) line 1.
[\code]
I'm not sure if I should be worried about the mismatch of wxpython. wxpython 3 is default on Archlinux, but I installed both printrun and slic3r against wxpython 2.8, which is still in the repositories. wxpython 2.6 is not in the repositories anymore and would cause more work.
The rest of the error message is pretty much gibberish to me.
Can anyone help me getting this to run? Help is much appreciated. I'm also happy to just use the console, without gui, as long as I know what to do.
Re: Software on (Arch-)Linux
November 06, 2015 12:48AM
I think I have a similar issue (Arch x64). Here's what I get:
List::Util object version 1.41 does not match bootstrap parameter 1.42 at /usr/lib/perl5/core_perl/DynaLoader.pm line 216.
Compilation failed in require at /usr/bin/vendor_perl/slic3r.pl line 13.
BEGIN failed--compilation aborted at /usr/bin/vendor_perl/slic3r.pl line 13.
My solution is to download a precompiled version. It runs fine.
November 06, 2015 07:42AM
Do you use the user repository? I use slic3r and printrun-bin (!) from the AUR and it now works as well. :-)
November 09, 2015 12:11PM
Yeah, I've tried them... If it makes a difference, I don't use the Slic3r copy built into pronterface, I like to keep my software separate.
