Re: plastic (composite) frame for reprap printers? November 04, 2015 10:40AM |
J-Max
For example, Instead of printing honneycomb pannels,
can't we print on foam to make usable and connectable pannels at low cost ?
++JM
Re: plastic (composite) frame for reprap printers? November 04, 2015 06:42PM |
realthor
in my case I would like the capability to create closed hexagonal chambers (at least by creating another skin every X mm in height but I'd like those to be random for each hexagonal tube, not all at the same height) rather than continuous tubes.
Something like this:
[attachment 65282 screenshot.426.jpg]
Imagine if half of those chambers where linked with holes in the walls, so you could dip the thing in some sort resin(expensive & messy) and it would soak into it through the network of pores. I know probably tricky due to size of the pores & viscosity, but if it could be done, the panels or parts could be quite interesting maybe even useful. Using 3D printing to print skeletal support lattices of some material that can be cured further or for use as a catalyst to react some other infill material could make for some interesting diversion from the choices available at the moment.
Edited 1 time(s). Last edit at 11/04/2015 06:43PM by MechaBits.
Re: plastic (composite) frame for reprap printers? November 04, 2015 07:39PM |
MechaBits
Re: plastic (composite) frame for reprap printers? November 04, 2015 08:59PM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 04:59AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 06:11AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 06:21AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 06:40AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 07:06AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 07:58AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 08:18AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 08:30AM |
the_digital_dentist
What's wrong with aluminum? Unlike the plastics we print with, it's almost 100% recycleable.
[/quote]Quote
the_digital_dentist
If you're really concerned about pollution, jobs, local sourcing, etc., take up kite flying instead of 3D printing. 3D printing is inherently environmentally unfriendly, as is almost everything else humans do.
Re: plastic (composite) frame for reprap printers? November 05, 2015 09:02AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 09:49AM |
DjDemonD
the_digital_dentist
Indeed - why aren't we extruding aluminium in our printers and making metal objects?
Re: plastic (composite) frame for reprap printers? November 05, 2015 10:21AM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 11:08AM |
the_digital_dentist
[...] and remember, almost no one is willing to pay more than $300 for a printer, even if it can produce an aluminum Yoda head.
Re: plastic (composite) frame for reprap printers? November 05, 2015 12:45PM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 03:26PM |
Re: plastic (composite) frame for reprap printers? November 05, 2015 05:02PM |
Re: plastic (composite) frame for reprap printers? November 06, 2015 05:09PM |
realthor
Do you still use it as a primary machine? I liked the PVC pipe connector set on thingiverse when I first saw it but don't fancy too much PVC in the apartment (I live in a studio for a while). I would try the same approach with wood dowels.
BTW, did you think about enclosing it to maybe be able to print with other filament than PLA?
One more: isn't it too light? Maybe fill the PVC pipes with sand or some vibration absorbtion material?
Re: plastic (composite) frame for reprap printers? November 06, 2015 06:04PM |
Re: plastic (composite) frame for reprap printers? November 06, 2015 09:30PM |
Re: plastic (composite) frame for reprap printers? November 07, 2015 05:24AM |
Re: plastic (composite) frame for reprap printers? November 07, 2015 04:46PM |
realthor
What would be the downsides or upsides? of a wood dowel similarly built strcture?
My personal opinion is that for apartments and for every home to have a 3d printer in 10 years as they predict the printers will either be a mini-fridge-size cool looking applicances lie any other applicance in the home or they will be unoptrusively embedded in the furniture. I just measured a wardrobe/cupboard shelf and it's 60cm deep and 50cm wide, with the height adjustable by the shelf pins. Pne can make a box fit that space and you got an enclosed printer. Of course the cupboard must be sturdy enough but they are usually by the wall so they are easy to bolt to the wall and it won't even show.
Re: plastic (composite) frame for reprap printers? November 07, 2015 05:51PM |
Re: plastic (composite) frame for reprap printers? November 08, 2015 10:19PM |
Re: plastic (composite) frame for reprap printers? November 09, 2015 03:49AM |
Re: plastic (composite) frame for reprap printers? November 09, 2015 07:41AM |
Re: plastic (composite) frame for reprap printers? November 09, 2015 08:48AM |
Re: plastic (composite) frame for reprap printers? November 09, 2015 08:59AM |
