steps/mm dilemma: is more than 0.1mm/microstep necessary? November 06, 2015 03:17PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 06, 2015 03:55PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 06, 2015 04:53PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 06, 2015 05:17PM |
dc42
Two reasons why 0.1mm/microstep is nothing like enough:
1. Not all microsteps are the same size. One reason for this is that the torque due to motor current has to compete with the detent torque.
2. The incremental torque per microstep is very low.You may have to command the motor to move more than one microstep in order to ovecome friction.
A Cartesian printer that had 10 microsteps/mm would suffer from severe Z banding.
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 06, 2015 07:37PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 06, 2015 08:13PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 07, 2015 04:50AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 07, 2015 07:05AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 07, 2015 04:32PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 07, 2015 05:59PM |
IMBoring25
A few other things...
Unless you want to not just level the bed but also set Z=0 using manual adjustment screws, you need a far finer adjustment than your layer height to optimally set the height for your first layer.
Fine resolution in Z would be needed if you are using autolevel or printing spiral vases.
What are you hoping to gain with coarser resolution? Since Z only moves a layer height at a time during a conventional print and always has an accompanying retraction, it will never be fast.
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 07, 2015 08:50PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 07, 2015 09:10PM |
julianh72
What I don't understand is what is the perceived problem with micro-steps for the Z axis?
julianh72
What does it matter whether it takes 10 or 100 or 1000 steps per layer change?
julianh72
There are definitely lots of advantages of being able to control your Z height in very fine increments - how would you print a 0.25 mm layer if your Z axis only moves in 0.1 mm increments?
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 07, 2015 11:47PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 08, 2015 12:43AM |
Once you start printing and calibrating, you quickly get an idea of what works well for your machine. I get results that I'm happy with using a first layer of 0.35 mm, and second and subsequent layers of 0.25 mm. If I could only position in increments of 0.1 mm, I guess I would try 0.3 mm / 0.2 mm, but that would be slower than 0.25 mm layers, and I don't know how successful it would be.Quote
realthor
I never thought it that way. I don't know why would you print 0.25 and not 0.3 or 0.2. It's like you would ask: "how would you print a 0.33 layer if tou can only do 0.05/microstep".
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 08, 2015 12:48AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 08, 2015 03:12AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 08, 2015 03:22AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 08, 2015 03:55AM |
etfrench
p.s. I think your initial premise about the resolution of 3d printers being .1mm is wrong by an order of magnitude.
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 08, 2015 04:06AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 08, 2015 08:10PM |
etfrench
Here's a source for honeycomb aluminum panels: [www.aliexpress.com]
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 05:09AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 06:44AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 06:53AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 07:07AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 07:26AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 08:06AM |
the_digital_dentist
When the printer is running if you turn on retraction/z lift (you'll need it to be on most of the time if you care about print quality- spiral vase mode being an obvious exception) the Z axis moves up and down multiple times as it prints each layer.
the_digital_dentist
The problem with printing pulleys (or gears) is getting them to come out round. If your X and Y axes aren't perfectly orthogonal and accurately calibrated, the pulleys won't be perfectly round. Using inaccurately printed pulleys would be a disaster. Belt tension will vary depensing on the rotational position. Ugh!
the_digital_dentist
You might be able you make a compact, low cost, and backlash free reduction mechanism by wrapping low-stretch fishing line around smooth pulleys...
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 09:42AM |
realthor
Is this Z retraction really used? Isn't it more sensible to use filament retraction instead?
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 10:31AM |
dc42
realthor
Z lift is commonly used on delta printers, because it can be used without sacrificing speed. Another reason may be that when using slow 8-bit electronics, the segmentation algorithm used by most delta firmwares causes the head to dip a little on fast travel moves. Z lift is not a substitute for filament retraction.
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 11:20AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 11:22AM |
