Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 11:34AM |
the_digital_dentist
The final pulleys are mounted on the machine and working fine, but the application isn't nearly as backlash-critical as yours.
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 09:41PM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 10, 2015 11:17PM |
the_digital_dentist
What is "friction gearing"? If you mean just wheels pressed against wheels, it may eliminate backlash but it may slip. I can see where meshing teeth could be a problem if you're trying to take pictures through a telescope.
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 11, 2015 07:23AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 11, 2015 08:46AM |
Re: steps/mm dilemma: is more than 0.1mm/microstep necessary? November 12, 2015 02:58PM |
