Z Height Setting November 09, 2015 11:29PM |
Re: Z Height Setting November 10, 2015 12:54AM |
Re: Z Height Setting November 10, 2015 06:28AM |
Re: Z Height Setting November 10, 2015 10:30AM |
Re: Z Height Setting November 10, 2015 11:11AM |
Re: Z Height Setting November 10, 2015 11:24AM |
DjDemonD
I see what you mean, and it makes sense. I might be wrong here but I think if you do not set a z offset the printer beings printing your first layer at z=0. Its only when you move up to layer 2 does the z axis lift. I'll check this evening in the workshop and get back to you.
Re: Z Height Setting November 10, 2015 11:33AM |
Re: Z Height Setting November 10, 2015 11:37AM |
Re: Z Height Setting November 10, 2015 11:43AM |
DjDemonD
DC42 okay so why do we need to add the thickness of a piece of paper offset to the nozzle either physically or electronically when we print. Simono71 would be right we should put the clean nozzle on the bed, call this z=0 then ask for a 0.25mm first layer, the z axis lifts 0.25mm and it begins to print.
Re: Z Height Setting November 10, 2015 10:06PM |
So what DOES your LCD show?Quote
DjDemonD
I know for certain that for example when I print a 2x2x1 cm cube it is not usually showing z=10 on the LCD when it finishes, despite this the part is 10mm thick (+/-0.05).
Re: Z Height Setting November 12, 2015 12:15PM |
Re: Z Height Setting March 09, 2016 06:22AM |
Re: Z Height Setting March 09, 2016 07:51PM |
