Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 11:03AM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 11:35AM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 02:02PM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 02:59PM |
J-Max
Hi guys,
Calculate here : [www.amesweb.info]
Keep in mind you want at last a flex 10 times under the precision you expect
Look at 8x350mm Prusa i3's to make up your mind
++JM
Re: Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 03:45PM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 06:49PM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 08:28PM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 24, 2015 09:05PM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 25, 2015 04:59PM |
Re: Is there any best practices for smooth rod diameter per hanging length? November 25, 2015 06:41PM |
SlowFoot
Missed the pulleys bearings and belts of the core-setup that will add some wight but I think the plastic is a bit too much so it will even out. The total error is the sum of the X and Y flex, I can't figured out if that is how this was calculated or not. And it - sign on the result indicate the direction of the flex, down.
Re: Is there any best practices for smooth rod diameter per hanging length? November 26, 2015 04:22PM |
