Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 26, 2015 10:32AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 26, 2015 10:59AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 26, 2015 11:10AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 26, 2015 11:48AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 27, 2015 12:35AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 27, 2015 03:13AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 27, 2015 04:46AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 27, 2015 02:56PM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 27, 2015 03:03PM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] November 27, 2015 03:28PM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] December 01, 2015 12:01AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] December 02, 2015 07:32AM |
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] December 02, 2015 12:45PM |
aliaj00
Advice, -> Get a new power supply.
It's starting to affect the voltage of the Arduino and if the power to Arduino goes in from that power supply then you are in trouble as Arduino need 5V.
Put a voltmeter to the power supply output "15v in your case" and see if it bounce to much "under-load i mean as during idle it will show ~15.something V", if you have a analog voltmeter the better so you can actually see if it sweeps to much. if the load it around 75% get a bigger PSU. switched mode power supplies don't go well when near capacity and the Arduino in noticing about it and resetting. or you power supply is getting ready to fail and the components are not handling the current as they should.
This is just my advice others may have other suggestions,hope it helps.
Timi,
Re: Stopped mid print, restart print from layer #, Repetier 1.5.6 [w/ screenshot] August 06, 2016 11:12PM |
