Reprapable linear drives ...
Posted by VDX
VDX
October 28, 2007 03:07PM
Hi all,
... on sunday i was with my youngest son in the basement at my parents house, where we 'revisited' some of my old projects from scool-time, nearly thirty years ago ...
One of them was a workaround, where i converted a Brother-HR1-typewheelprinter in a pen-plotter for my oldstyled Commodore C64-homecomputer.
It was really working after the long time - a condensator in the powersupply fumed, but didn't change anything winking smiley
I checked, if the Printer-mechanics was worth to salvage and found, that the carriage wasn't driven by a steppermotor with a tooth-belt as usual, but was a direct-drive linear-stepper!!! - here the carriage holds several slightly displaced coils with small toothed iron-cores and a massive iron-bar as feeding, with same toothing as counterpart works as linear stepper-motor-setup, to travel the carriage by switching current in the right cores ...
Then me struck the idea, that a similar setup could easily be reprapped, when i insert magnets in the feeding and complementary coils in the mover.
So the X- and Y-axis with motors and feeding could be made completely by the reprap or from aluminium-blades and some feeding rolls ...
Here is an image, to show how the setup of a magnet<->coil linear stepper-drive could be arranged:
The magnets could be bought at [www.supermagnete.de] , the coils could be salvaged form old electromechanic switches or from telecom-relays ...
Viktor
Re: Reprapable linear drives ...
October 28, 2007 03:51PM
Hi Viktor,
How was the precision on the stepper? And how large were the magnets and coils? To get a decent range of movement, it would seem that you would need a _lot_ of magnets. Sounds like it could get expensive quickly, especially at >0,50 eu per magnet (>$.70). Still, it probably can't be _too_ much more expensive than the current stepper motors for Darwin, at about $60 each. If you could think of a decent pump, then I think I still like artificial muscles more. Of course, they could end up being harder to reprap.
Any ideas on how to make home-made magnets? Cheaper than manufactured? I doubt it, but it would help in making motors.
-Samuel
VDX
October 28, 2007 04:19PM
Hi Samuel,
... 'China'-magnets can be cheap bought in big amounts for some cents each, so in bulks bought in Asia it's not so expensive ...
The coils can be wound manually with a drill, so it's best homemade ...
And the accuracy is dependant of the relation: step-width of the magnets against the amount and displacement of the coil-series - with aligned series of 8 coils in 4 rows i can make 32 full steps over the width of an magnet or 8-fold (= 256), when i use microstepping (some microstep-drivers output 1/128 steps!).
So a setup with 5mm-magnets would allow 0,02 mm per 1/8-micro-step ...
If you use thinner magnets or a finer milled toothed surface, as in the Brother-drive, then you can rise the accuracy to a higher level without using magnets.
So the question is, can i find very cheap magnets, or is it easier to mill the surface of a iron-feeding, to build a magnet-free linear drive, which only moves through induction?
To make magnets or magnetized objects at home you can use NdFeB-magnet-powder, mix it with an elastic airhardening or heatcuring resin, fill the paste in a form and apply a very strong magnet or solenoid to the form to 'teach' the polarity in the paste, until it harden - then you have a plastic-based magnet with a free defined form and field-geometry with maybe 70% to 80% the strentgh of a 'normal' NdFeB-Magnet (e.g. 0,9 Tesla max for a 'standard' mixture)
Viktor
October 28, 2007 05:07PM
That magnet powder sounds interesting. It could be useful to be able to extrude our own magnets of varying shapes. Any idea where to buy the stuff or how much it costs?
-Samuel
VDX
October 28, 2007 05:48PM
... i had some tsting with powders from VAC in germany - they fabricate high-quality but expensive magnets.
Maybe the guys at www.supermagnete.de have some - i'll ask them ...
Viktor
December 06, 2007 10:18PM
Edit: never mind
Edited 1 time(s). Last edit at 12/06/2007 10:19PM by sillyarms.
December 07, 2007 01:26AM
I think this idea is fantastic!!
It has always been my feeling that There were 3 big hurdles to be overcome before RepRap could really become self-reproducing.
1: strong rigid structural members - Replacements for the metal rods in Darwin-
this is not a fundamental problem, either create a printer based on a sturdy plastic box (simple but uses lots of plastic) or find a way to use RepRap to create molds for casting and tools for finishing metal pieces (more complicated but doing these things is probably an inevitable part of the machines' development) or find a way to extrude rigid elements from other materials such as carbon fiber composites (probably farther out technologically).
2: circuitry - teaching the machine to create the electronics for itself -
the level of difficulty here runs from minimal to massive depending on your definition of "create the electronics". A printhead for circuit traces is probably going to be part of Mendel (just a guess) but that leaves a person to assemble and solder the actual components into an actual circuit. This is probably the most daunting part of the assembly for some people(me). On the other hand getting a machine to do that type of work is the cutting edge of current AI research. Some possibilities for intermediate level of self assembly include developing a fab-able circuit board based on a proto board so that pieces can be simply inserted according to a diagram printed on the board and it will work without soldering, or again, farther down the road, the technology to fab electronic components in place
3: motors - teaching the machine to create its' own mechanical actuators -
this is finally the reason this rant is posted here. How to fab motors has always been a sticking point. Decently efficient electric motors are precision instruments well beyond anything we are realistically talking about extruding and even with CAM machine tools the setup, assembly and testing would be daunting. Artificial muscles are (my opinion) at the same technological distance as fab-in-place circuitry. BUT.... if we can fab the magnetic strip, as seems likely, the rest seems fairly straight forward, winding electromagnets is easy and the framework to hold it all in place is simple and not too highly stressed. To increase the force available we just add extra rows of electromagnets in parallel over a wider magnet strip. The software is stepper software and registration marks could be printed on the strip to allow it to be used as a servo. If we can do away with the need to buy our 3 largest motors (which are also our most expensive items) we may have slain the last of our demons.
OK- real bearings are a challenge but still...
December 09, 2007 03:43PM
Hmmm
Like the idea of linear drive.
I think we need an stl design, motoring and circuitry for a universal winder.
Coiling automated bliss, by hand erm sperm of the devil.
I need one anyway as on my list of items to reprap is a leccy windmill.....
cheers
aka47
Necessity hopefully becomes the absentee parent of successfully invented children.
December 11, 2007 01:15AM
Ah, the windmill idea! Great one that has been tossed around before. Don't know if the link is still up in the wiki but had a great bit about making a windmill from odds and ends. Very awesome. Must have one (20) myself.
Demented
December 11, 2007 02:24AM
I can recommend as reading anything by Hugh Piggot. He's a Scottish guy who lives on the scoraig peninsula does wind power to death.
Particularly making your own alternator/wind turbine using break drum components in the building of the alternator.
Clever guy with shed loads of kitchen table technology, including lathing molds for permag, axial alternators using a made up lathe from a washing machine motor. (My sort of guy)
He has published a very good book that was available from CAT (Centre for Alternative Technology, Macllineth Wales, [www.cat.org.uk]) Called Wind Power Workshop.
I think he also has a web site Scoraig Wind Power as well as a consulting business doing the same.
Sorry I guess this appears slightly off topic
Back to winding coils for linear motors. Hugh's designs for alternators and wind turbines do include a load of useful stuff on motors. alternators and winding your own coils. So whilst being for something other than linear motors, his stuff on three phase alternators is directly transferable.
The three phase method of overlapping coils on a suitable ferro former can of course be layed out in a straight strip. to form the linear armature.
Although I think Viktors idea above potentially cooler, 3 phase isn't that new or trendy.
For making a ferro former I think it should be possible to reprap a plug for molding the plate from resin filled with something magnetic i.e. ferrite or some such, possibly in a three step process. (although one to two would be better, Ferro component followed by encapsulant after coil insertion).
I think Viktor is probably going to be the man when it comes to suggesting a suitable filler/resin combo, I get the feeling it could even be something that he has had a crack at, at some time or other.
Additionally is it worth considering using victors method as above but standing the magnet strip up on it's side. The motor coiled bits could then be arranged like the letter C with the open part of the C sitting over the strip and the coils arranged one on each arm of the C giving a N and a S for each magnet straddled ergo twice the grip/strength. I remember reading somewhere that it is better to coil this way rather than around the middle of the C shape of the magnetic circuit as it concentrates the Magnetic flux better across the air gap. The C shape creates a better magnetic circuit too. Sorry can't remember where I read it but it makes sense if you plot lines of magnetic force and think of magnetism in terms flow, a bit like current. (Remember the iron fillings, paper and bar magnet thing at school)
Thoughts for what they are worth.
What do you guys think ??
aka47
December 11, 2007 08:37AM
Andy,
Standing things on there side sounds pretty good. I can't think of any drawbacks off hand but I'm sure Viktor will have something to say on it. There still hasn't been a post as to the cost of this magnetic powder so I wouldn't go jumping the gun yet. Could be _quite_ expensive. Time will tell.
Demented
VDX
December 11, 2007 10:04AM
... here an update:
The guys at Supermagnete.de didn't sell powder, VAC didn't want to give their parts away, so i actually didn't find usable NdFeB-powder, but will try further ...
For a selfmade approach there could be made some hard-magnetic powder by chrunching down big magnets with a ball-mill or try to find ready NdFeB-resin-strips (should be silvery-coloured instead of brown-black as with Ferrite).
Most of the magnetic-strips are already magnetized alternating, that's what we need!
But the normal ones with Ferrite are so 'soft-magnetic', that you can easily remagnetize them with a powered coil ...
My hint is to try with toothed iron-bars - i have some linear gear-sticks from iron salvaged from old copy-printers, so they should be common in stores, that sell ACME-spindles too.
Then you didn't want to mess around with magnetic stuff, but can build pure inductive drives with coils to iron-teeth-orientation ...
Viktor
December 11, 2007 12:12PM
Hmmm
The ferrite or ferous material to use as filler doesnt want to retain magnetic field otherwise the linear would be severely impared.
The Resin and Ferous filler is a replacment for the soft iron laminations in a motor/generator that complete or form the magnetic circuit.
A ferrous filler that has a high hysteresis ie retains too much of the orientation of it's last magnetisation will resist the change in polarity when you switch the current in the coils the other way around (as in stepper, or motor). Bad, bad, bad.
A soft iron powder should do provided you can make sure that there the end product resin + filler does'nt readily conduct (preferably not at all for the voltage ranges likely to be induced) this is to eliminate/reduce eddy currents (The things that make transformers hum and get hot).
For filler I was thinking more of Ferrite as in ferrite rods or pot cores ground up if you cannot find a supplier of the powder that ferrite rods and pot cores are cast from.
High hystererisis = low coercivity which in magnetic circuits is bad.
Overall I think Viktors idea re magnet strip was excellent but needs standing on it's side. the coils/placment and magnetic circuit need a bit of thinking about but are probably 50% of the way to something.
Once you have an apparently viable design then it can be costed and if looking favorable trialled ...
More thoughts probably worth even less.
aka47
VDX
December 11, 2007 02:23PM
... for induction-driving without magnets: - the common toothed rods can be found as "rack and pinion"-setups.
When using the rack-teeth instead of magnet-poles, it's the same as with non-magnetic stepper-motors - the active coils 'snap-on' at the nearest tooth, so with more slightly displaced racks and fitting coil-arrays you can build the same fine-moving linear motors as with the magnetic setup.
Only if you cut off the current, there is no holding-force as with magnets.
When i'll disassemble my Brother-typewheel-printer with the linear motor, then i would make some photos - here is the same principle without magnets working ...
Viktor
VDX
June 01, 2008 02:59PM
... update ...
For a thread in another forum i disassembled the Brother-HR1-printer (see the first post in this thread) and made some photos of the linear drive.
The printer (the steel-barn is the toothed stator):
Toothed stator:
The coils with toothed iron-cores (4 coils in a row):
Viktor
June 02, 2008 12:21PM
I've been thinking about this idea, and I'm glad others are thinking of it as well.
It might be possible to build an electromagnet out of simple solder and plastic. The arrangement should be simulated, I'm wondering if there are any programs out there that can simulate magnetic fields.
I think that if you made a board with grooves, then filled those grooves with solder, then covered those grooves with a layer of plastic, then you'd have the makings of a shielded cable that could be used to connect to the RepRap-ed stepper motor. This board could then also serve as the interface between the drivers for your motors. The drivers should be integrated into one unit, the Arduino unit, so that this one unit can be distributed and integrated into one place easily, which would be the electrical distribution board.
This will be the component that is un-RepRap-able, which would be a future Arduino unit. This could be manufactured in bulk and distributed, however.
The Arduino should be able to accept a USB-key (someone said this earlier), and if the key has an LCD display, the key can select existing open source STL files.
So, those are my assorted thoughts on this subject. smiling smiley
VDX
June 02, 2008 02:08PM
... here: [femm.foster-miller.net] you can download a free finite-elements-simulator for magnetic fields (for Windows).
Viktor
June 02, 2008 02:22PM
I'm looking at figuring out how to Reprap these.
I'm for using a spark erosion machining head for Tommelise 2.0 to do the job. That way I don't have to worry about the tool loading that ordinary routers and grinders put on my xyz positioning system. smileys with beer
[en.wikipedia.org]
Edited 2 time(s). Last edit at 06/02/2008 02:46PM by Forrest Higgs.
June 02, 2008 08:08PM
Why use EDM when you can use the simpler electrochemical machining: [fabathome.org]
But having a homemade ECM or EDM machine would really cool, EDM is accurate enough to make the molds for coins.
Ru
June 03, 2008 03:22AM
I see to recall the willitblend guy made magnetic powder by blending up rare earth magnets. Not sure how useful they'd be after that beating, but it was certainly magnetic winking smiley
VDX
June 03, 2008 04:05AM
Hi Ru,
i already mentioned using elastic magnetic stripes made from NdFeB-powder embedded in resin (see 3-rd post).
But for orienting the magnetized particles in the hardening resin you need much more magnetic field than usual, as you have to overcome the high forces between the already magnetized particles to rotate them in the right direction ...
Viktor
Ru
June 03, 2008 04:12AM
Oh yes, I did read the whole thread. I was just commenting on the fact that no-one seemed to have found a suitable source of magnetic powder.
June 03, 2008 07:25AM
Do we need magnetic material? You can make an electromagnet out of a ferrous material and an insulated, conductive material wound around it.
June 03, 2008 09:35PM
Greetings all,
I'm new to this forum, so please bear with me.
This type of linear stepper motor is also known as a Sawyer motor, after the inventor. The patent citation is Sawyer, B., \Magnetic Positioning Device," U.S.
Patent 3,376,578, April 1968. Online (w/the right plugin) at: [patft.uspto.gov]
Making such actuators doesn't need large numbers of magnets, just lots of little iron (or other magnetic meaterial) teeth, usually carved into larger structures. There's a good diagram on page 21-66 of [pergatory.mit.edu]
The extension to 2-D has also been used in robotic workcells for small part assembly, by at least three companies: Automatix Inc.,
AT&T Bell Laboratories, Megamation. (I don't know if any of these are still being made, though.) I think this was also used as the basis for a high-speed plotter, but I can't recall the name of the company (except that it had XY in the name.) In the 2-D version, the two pieces are often separated by an air bearing.
These are certainly cool, but (if memory serves) usually are best in high velocity, relatively low force applications. (Much easier to gear rotary actuation, so these may not be the best match to rep-rap, but that's only a preliminary guess, not having even slept on it.)
It seems to me that for actuators, not being able to use iron/silicon steel is a serious drawback, so I'm dreaming of a reprap that can do both additive and subtractive machining.
-- Larry
June 04, 2008 06:38PM
We have a few of these kicking about at work
[www.eclipse-magnetics.co.uk]
And a really large one on the big CNC machine (6'x4' at least) that can do 15mm cuts through plate steel with a 10mm cutter at high speed, with the magnet holding it in place easily.
Cant see an online vendor for pricing though....
Building it out of a pair of electromagents is more rappable than a perm and electro really.
J.
June 04, 2008 06:45PM
Hmm pricey (more than ball screws)...
[www.chronos.ltd.uk]
Near the bottom, but the concept is still there, you could ask supermagnets to deliver a unit which is one piece and suitable that has 1mm protrusions like a H to achieve the same effect, and reprap the gaps in the H with plastic.
J.
May 27, 2013 01:08AM
I had built a very similar design at one point. A linear drive used two coils that had C-shaped laminated cores. Both ends of the core were employed in the process when a coil was energized...
I used ready-made junk parts. My machine crawled across a 2D table. A permanent magnet held it flush to the surface of the glass. Soft iron stock cubes were used to attract electromagnets. Plastic beads were used to space those cubes evenly before the asphalt caulk solidified...
I really want to develop this idea. I live in Frederick MD, USA.
Everything else was the same, the way vernier calipers work...
VDX
May 27, 2013 01:56AM
... there were some professional developments with 2D tooth-milled steel-plates as stator grid and multiple 'planar steppers' arranged in a form so the moving part could be displaced linear with some ten microns accuracy and/or or rotated with high angular resolution.
The XY-positioning feedbach was made with PC-mouse ssensors ...
Viktor
May 27, 2013 06:06AM
> Demented
have you checked this out vertical axis wind turbine
