step angle is 1.8. this is a normal 200 steps per rotation stepper. According to [
www.nanjixiong.com]
most likely you have the max feed rate set to high.
If your lucky you have eeprom enabled and you can just set it one in software and your done
send a m503 to your printer (Print settings), if this works you might be in luck.
Look for the line that starts M203 in the output, these are the current max feed rates for x,y,z,e
Z will probably be 5, this should be 2 for a m5 based z axis
set z max feed rate by sending M203 Z2 to the printer
Send a m500 to save this all setting to eeprom.
Cross your fingers and try again.
Edited 1 time(s). Last edit at 12/02/2015 04:28AM by Dust.
