Turning up Power Supply voltage with Duet Controller? December 04, 2015 03:32PM |
Re: Turning up Power Supply voltage with Duet Controller? December 04, 2015 05:19PM |
Re: Turning up Power Supply voltage with Duet Controller? December 04, 2015 06:14PM |
Re: Turning up Power Supply voltage with Duet Controller? December 04, 2015 08:12PM |
Re: Turning up Power Supply voltage with Duet Controller? December 05, 2015 03:07AM |
Re: Turning up Power Supply voltage with Duet Controller? December 05, 2015 08:11AM |
patrickrio
yes, it is insulated with corkboard.
I am using a standard MK3 circuit board heater with aluminum heat spreader attached. Not sure how many amps this bed draws when overvolted. Any calculation I can use???? I will also be increasing the potential wattage of the ceramic extruder heater.....
