Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" December 17, 2015 12:46AM |
DCM's volatility and ability to dissolve a wide range of organic compounds makes it a useful solvent for many chemical processes.[10]
It is widely used as a paint stripper and a degreaser.[13] In the food industry, it has been used to decaffeinate coffee and tea as well as to prepare extracts of hops and other flavorings.[14] Its volatility has led to its use as an aerosol spray propellant and as a blowing agent for polyurethane foams.
Specialized uses
The chemical compound's low boiling point allows the chemical to function in a heat engine that can extract mechanical energy from small temperature differences. An example of a DCM heat engine is the drinking bird. The toy works at room temperature.
DCM chemically welds certain plastics. For example, it is used to seal the casing of electric meters. Often sold as a main component of plastic welding adhesives, it is also used extensively by model building hobbyists for joining plastic components together. It is commonly referred to as "Di-clo."
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" December 17, 2015 01:19AM |
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" December 17, 2015 04:38AM |
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" December 17, 2015 06:23AM |
etfrench
Skimmy
The coating I am talking about is so thin, that you can not see it.
It sounds like the Emporer's clothing
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" December 18, 2015 02:43AM |
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" December 18, 2015 04:31AM |
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" February 03, 2016 04:47AM |
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" February 03, 2016 08:06AM |
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" February 03, 2016 10:29AM |
Re: PEI-coated-aluminium-printbed a.k.a. "the german Dauerdruckplatte" February 03, 2016 10:34AM |
