Extruder motor not working
December 16, 2015 01:30AM
The extruder motor is not working, the stepper diver ,stepper motor and the wires are ok. I have tried switching the stepper drivers , the wires and even the motors but none seems to work. I have also re istalled the firmware.
Is there a problem with board or the extruder stepper driver port ??
please help
Edited 1 time(s). Last edit at 12/16/2015 01:31AM by rizulthkr.
Re: Extruder motor not working
December 16, 2015 02:49AM
what does the temperature read?
If that’s not correct, it will disable the extruder, it also will not allow cold extrusion...
Best to start with a pc connected and run something like pronterface, other applications can hide important messages
Get the lcd your having issues with working later... after basic functionality is working.
Edited 1 time(s). Last edit at 12/16/2015 03:10AM by Dust.
December 16, 2015 03:14AM
yes i know about cold extrusion , so i heat it up then try to extrude , but the motor wont work
December 16, 2015 03:41AM
Do you know about the setting the POT on the stepper driver? This set the current limits.
December 18, 2015 01:16AM
yes i know and i have tried that. I guess it is the problem of the extruder port. do you know how to repair it ??
