Buildtak application
Posted by WZ9V
December 27, 2015 05:57PM
I've watched the videos and apply it as they say using an old Credit Card to smooth it out as I apply it, but I still seem to get bubbles under it when using it with my heated bed. I attached an image of what the back looked like when I removed it from my glass plate.
Any suggestions? Too much heat, not enough pressure smoothing it out?
Re: Buildtak application
December 27, 2015 08:01PM
Does it have bubbles when the bed is cold?
December 27, 2015 09:38PM
Not at first but it seems to develop them over time.
epicepee
December 28, 2015 12:05AM
It might be too late, but I use the wet method to apply the Buildtak. Wet the surface you are going to place the Buildtak on with window cleaner. Apply the Buildtak on the wet surface and position it where you want it. Then use the credit card to squeeze the liquid out and the Buildtak will stay in place. No air bubbles when doing it this way.
Edited 1 time(s). Last edit at 12/28/2015 09:15AM by ElmoC.
December 28, 2015 10:48AM
Not too late, looking for ideas to get it right for a new sheet of BuildTak.
Anything in particular to look for or avoid in the window cleaner?
December 28, 2015 11:08AM
I just use cheap generic window cleaner. Nothing special. Soapy water will also work.
