PT100 amplifier board
Posted by Tomsand
January 20, 2016 10:31AM
I have some Ultimaker2-style PT100 sensor that I want to connect to my RUMBA.
Are there any cheaper amplifier boards out there that I can use to do that?
I would've bought these but it's getting expensive when you need 6 of them.
Re: PT100 amplifier board
January 21, 2016 04:06AM
[www.aliexpress.com]
Edited 1 time(s). Last edit at 01/21/2016 04:07AM by karabas.
January 21, 2016 06:12PM
I know these and they are from very poor quality. Any other recommendations?
January 22, 2016 12:15AM
I run Filastruder, an E3D distributor. I might be able to help, shoot me a message using the Filastruder site's contact form.
January 28, 2016 06:41AM
Tomsand
What is the source of this info?
January 28, 2016 02:36PM
Best check what sort(s) of amplifier board the firmware that you intend to run will support. There are two sorts of RTD amplifier board: linear amplifiers that connect to an analog port, such as the E3D board; and amplifiers based on the MAX31865 chip with a digital (SPI) output, that connect to the SPI pins in the same way as most thermocouple boards.
June 27, 2016 08:50PM
I bought the E3D set cuz of its positives recommendations but I still do not figure how to make it work with my new Rumba, I know that is something in the Marlin code, the wires comes with some plugs all ready installed, but they do not look like to be design for the Rumba. I am a little confused.
June 28, 2016 04:34PM
See here for your reference: [wiki.e3d-online.com]
You need to find a free analog pin in order to assign it to your firmware. The Rumba board schematic will point the available pin number.
[reprap.org]
Look for EXP3, it shouldn't be used, I think.
DYZE DESIGN
Hotends, Extruders, Liquid Cooling and Accessories.
June 29, 2016 08:46PM
Thank you Dyze Design ! That help me a lot! All is working a lot, so I hope to be able to print PC! Thank you again.
