Re: Custom builder wanted. January 26, 2016 06:32PM |
Re: Custom builder wanted. January 26, 2016 06:55PM |
RPearce
1.75mm .04 nozzle
Re: Custom builder wanted. January 26, 2016 06:56PM |
Re: Custom builder wanted. January 26, 2016 07:10PM |
Re: Custom builder wanted. January 26, 2016 08:40PM |
Re: Custom builder wanted. January 26, 2016 09:00PM |
Re: Custom builder wanted. January 27, 2016 08:56AM |
Re: Custom builder wanted. January 27, 2016 09:27AM |
Re: Custom builder wanted. January 27, 2016 10:12AM |
I'm not lost on anything here. I have also designed, machined and assembled a printer that has been working for about a year now. You won't get the bed flat within your layer height, and I'm not aware of any firmware that will compensate for your inevitably bowed and warped bed. So spend your money, tell us we are lost. You obviously know better than the people here who have actually done things. Why bother to even ask for advice?Quote
RPearce
I ment, .4 nozzle I print in generally. .2mm layer height. And I can tell by the comments most of you are quite lost on the design, the bed was always stationary other people suggest that it move. As for the Prusa part, the idea was to take the gantry of a prusa and just make it bigger to reach the required spec.
Re: Custom builder wanted. January 27, 2016 11:13AM |
Re: Custom builder wanted. January 27, 2016 12:48PM |
cozmicray
See the Shapeoko CNC machine for ideas
[docs.shapeoko.com]
You desire a X axis gantry where the entire gantry moves up/down in Z
Trolleys and drive from this type of machine maybe a inspiration.
Might want to look at Vee rails for trolley tracks
[www.vgrooverail.com]
Re: Custom builder wanted. January 27, 2016 01:15PM |
Re: Custom builder wanted. January 27, 2016 06:05PM |
Re: Custom builder wanted. January 27, 2016 06:09PM |
Re: Custom builder wanted. January 27, 2016 06:53PM |
Re: Custom builder wanted. January 27, 2016 10:51PM |
RPearce
cozmicray
[docs.shapeoko.com]
This guy is knows what up, that's perfect! Now how do I make it work for 3D printing?
Re: Custom builder wanted. January 28, 2016 11:56AM |
Re: Custom builder wanted. January 28, 2016 12:45PM |
the_digital_dentist
Where does the idea that a piece of glass is flat and won't flex come from?
Re: Custom builder wanted. January 28, 2016 12:56PM |
Re: Custom builder wanted. January 28, 2016 01:33PM |
DRobs86
I am open to correction, but its my understanding that glass plate is much much flatter than aluminum plate. I didnt say it was necessarily stiff, but it laying ontop of his wavy aluminum plate is a better print surface.
Re: Custom builder wanted. January 28, 2016 01:40PM |
JamesK
For many years glass was used as a reference surface plate for accurate marking out in machining, so that's probably where the idea came from. My recollections of those pieces of glass is that they were typically 3/4 to an inch thick - a bit different from the typical 3mm often used on printers, and I believe glass used for surface plates was ground, not just used straight from the float process. Apparently granite is the material of choice for surface plates these days.
Re: Custom builder wanted. January 28, 2016 01:41PM |
It is pointless to generalize "what is flatter". Material varies, and doesn't always meet spec. An indicator and a known reference flat will tell you the actual answer. As well as the you actual info if it isn't within spec. Glass isn't inherently anything, and can and does bend, especially at the size in question, and especially when it's base isn't flat.Quote
DRobs86
the_digital_dentist
Pearce feel free to use whatver you like. Its your money you are spending, but its just childish to ignore people who have done successful custom builds saying "that wont work and here is why." This is what irks me about the Reprap forum. There are some real innovators here, but for every innovator there are 30 guys saying they want to build a machine much larger than a conventional printer without an ounce of disciplined engineering effort all the while ignoring those who provide reasonable guidance.
Re: Custom builder wanted. January 28, 2016 01:50PM |
Re: Custom builder wanted. January 28, 2016 07:05PM |
JamesK
Re: Custom builder wanted. January 28, 2016 08:28PM |
Re: Custom builder wanted. January 28, 2016 09:19PM |
Koko76
The op won't use glass any way, so it's kind of moot. I'm also interested to know what kind of material will be printed on this machine.
Re: Custom builder wanted. January 30, 2016 11:15PM |
Frans@France
Maybe try this mostly (3d) printed CNC [www.thingiverse.com] which can also be extended to be used as an 3d printer [youtu.be]
Re: Custom builder wanted. January 31, 2016 01:12AM |
Re: Custom builder wanted. January 31, 2016 07:54AM |
Re: Custom builder wanted. January 31, 2016 11:36AM |
