Geared Extruder Nozzle...Pictures Posted...Now on Ebay
September 28, 2010 10:22AM
Hello,
I just placed an order for the raw materials to start making the Geared Extruder Nozzle (http://www.reprap.org/wiki/Geared_extruder_nozzle). I should be able to have the first batch by next week and the cost will be $45.00, plus shipping and handling.
The parts kit will include the PTFE insulator, the brass nozzle, the heater block (and resistor), and the PEEK block. Due to the lack of availability of metric-sized stock, there will be some slight variations. For example, the PEEK block will be 3/8" thick as opposed to 10mm.
I'll also leave drilling the 2 mounting holes, in the PEEK block, up to the user as that will allow other sizes of threaded rod to be used.
Regards,
Brian
Edited 4 time(s). Last edit at 10/21/2010 10:04AM by reifsnyderb.
Re: Geared Extruder Nozzle
September 28, 2010 02:54PM
That's great! I am interested in ordering !!
October 04, 2010 04:53PM
If you are going to offer a peek block, you may as well either drill pilot holes or 3mm holes to be drilled out to fit larger sizes of threaded rod. (I can't imagine anyone wanting to go smaller than M3?)
October 07, 2010 09:52PM
Hello,
Good point. I can do that.
Regards,
Brian
> M3?)
October 07, 2010 09:54PM
Hello,
Progress is being made. I might be able to get the first production run finished this weekend. (No promises.)
Thus far, I have the PEEK blocks ready for drilling, the heater blocks ready for drilling, and the first operation completed for the nozzles. I am planning on completing the first run of nozzles tomorrow evening.
Regards,
Brian
October 08, 2010 02:27PM
Hi Brian
that's great news, are you still happy to ship to the UK?
My first nozzle from you is performing very well.
Are you happy to make a minor mod or two if requested?
[richrap.blogspot.com]
October 08, 2010 02:34PM
richrap Wrote:
> Hi Brian
> the UK?
> requested?
Hello,
Yes, I will ship to the UK, along with practically anywhere else where there aren't any serious restrictions.
It's good to hear that parts that I have machined are working well! I am glad that you are happy with it.
I can make minor modifications as long as I have the tooling and the setup is fast.
Regards,
Brian
October 08, 2010 09:13PM
Nozzles are done!
Cancel that. I was going to thread the external threads, by hand, for the first batch and see how they sell. Unfortunately, they bend easy and I just noticed that hand-threading results in the ends being bent.
I may have another solution involving the lathe an a die head.
Next are the thermal barriers. Then, I just have to drill holes in the heater blocks and PEEK!
Regards,
Brian
Edited 1 time(s). Last edit at 10/08/2010 09:31PM by reifsnyderb.
October 08, 2010 09:50PM
Ok, now the nozzles are done! I had to thread, with a die, them on one of my lathes.
Regards,
Brian
More setbacks....
October 15, 2010 09:14AM
Hello,
I am back on track to making a short production run of these nozzles. My drill press broke and created some problems so I am now drilling out the rectangular pieces on one of my lathes.
Regards,
Brian
Re: More setbacks....
October 15, 2010 11:08AM
I've ordered from reifsnyderb and he is a good seller. I was actually going to ask you if you could make these, and now I know the answer. I'll be interested in ordering one when they are done.
October 15, 2010 11:40PM
i'm interested in the complete package if i could see some photos at some stage. I was wondering what diameter are the holes of your nozzle? .5?
October 16, 2010 12:24PM
Hello,
I'll post pictures when they are finished. The edges of the PEEK block will be a little rough (i.e. very fine grooves) as the PEEK is cut with a bandsaw. I can make the nozzle holes 0.25, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, or 1.0mm. As with the other nozzles, that I make, I'll drill the orifice as per each order. By default, I'll drill them to 0.5mm.
I just need to drill one more hole, in the heater blocks, and the 3mm holes in the PEEK. I really need to find a faster way to drill all these holes.
Regards,
Brian
October 16, 2010 08:34PM
I too am interested in at least one of these, and possibly a few barrel tip/heater blocks separately. Given the design, it looks like it's possible to swap these parts over without really interfering with the rest of the setup, so it may be possible you could change orifice sizes without replacing the entire extruder (eg: removing the PTFE part).
How much would it be for additional nozzles and heater blocks?
October 16, 2010 09:16PM
I wish I had known you were going to make these before I bought one of your nozzles tongue sticking out smiley
I do have to say though that your machining is excellent, and so far the nozzle I bought is working great.
To everyone else, I would definitely recommend doing business with reifsnyderb.
October 17, 2010 07:13AM
Well i just send you a pm from your thread in the forsale section. then i find this one .
Maybe this is the better answer, any word on these being available?
October 17, 2010 10:32AM
Hello,
Unfortunately, the PTFE part is different as it has external threads and screws into the nozzle. The pricing, for the parts, breaks down as follows:
PEEK insulator block: $18.00
Heater block and resistor: $10.00
Nozzle: $10.00
PTFE Thermal Barrier: $7.00
Regards,
Brian
> PTFE part).
> heater blocks?
October 17, 2010 10:34AM
Thanks!
> working great.
October 17, 2010 10:45AM
Hello,
I just sent you a PM. These will be available real soon and I can probably ship a couple tomorrow. (One may be shipping out tomorrow.)
Right now, I have the following:
20+ PEEK blocks (still need to drill the m3 holes)
20+ heater blocks (still need to drill the heater resistor hole)
9 good nozzles (I had a total of 15; but, I botched the external m6x1 threads (bent the nozzle) on my first threading attempt. I didn't realize it until I started examining them that they were slightly bent. I changed my method of threading them and they look good.)
0 PTFE thermal barriers (I will be making a small batch today, however, I need to order more 5/8" PTFE as I need to make some 35mm standard PTFE thermal barriers as well)
I have had some setbacks and challenges: I had to figure out how to setup the rectangular pieces in order to quickly drill all the required holes. My drill press broke. The rectangular pieces require a lot more handling than the round parts. Etc.
Regards,
Brian
> being available?
October 17, 2010 05:28PM
> follows:
> Nozzle: $10.00
Oh I knew that. I was meaning buying additional heating blocks and nozzles beyond just a single set. In theory, you could just swap them without having to swap the thermal barrier.
October 17, 2010 06:45PM
Ok, I understand. The only concern, that I have, about swapping nozzles is that if melted plastic gets in the threads the PTFE thermal barrier could break if you try to unscrew it.
Regards,
Brian
> > follows:
> > Nozzle: $10.00
First Pictures
October 17, 2010 10:13PM
Hello,
Attached are the first pictures of a nozzle that ships out tomorrow. Since there are a multiple holes that need to be drilled in the two rectangular pieces, I am looking into multi-drilling solutions in order to optimize the process.
Regards,
Brian
open | download - gen1.JPG (140.9 KB)
open | download - gen2.JPG (78.2 KB)
October 17, 2010 10:54PM
Wouldnt it be easier to just swap the nozzle and thermal barrier, unscrew the heater and retainer.
keep the nozzle and thermal barrier together .
would make sense to me. slightly more exspensive as you need a barrier for each nozzle but easy enough to swap i would think
btw, nice pics.
Re: Geared Extruder Nozzle...Pictures Posted
October 18, 2010 12:37AM
either that or 2 drill presses and a friend winking smiley
So they look great, is it still $45 for the whole shebang?
Could you let me know about postage and handling to sydney australia? postcode 2222.
October 18, 2010 02:10AM
PS you might want to also post about this here:
[forums.reprap.org]
October 18, 2010 09:16AM
Hello,
I charge $6.50 for international shipping and handling to any country that it is legal to ship to.
Regards,
Brian
> shebang?
October 18, 2010 09:22AM
Hello,
Once the first batch is finished, I'll sell them on E-bay as there will be some delays between batches until I get all of the manufacturing problems resolved.
I'll put them up for sale other places once I figure out a fast way of making all of the parts. At the present, my shop is mainly setup to make round parts quickly. I need to come up with a way to make the rectangular parts quickly.
Regards,
Brian
> [forums.reprap.org]
KmE
October 19, 2010 07:08PM
Hi Brian,
They look really nice smiling smiley
A couple of questions;
    [1] What is the connection between the threads of the barrel and heater block like- i.e. would it benefit from some thermal compound to transfer the heat?
    [2] Will you be selling the seperate parts on ebay when they are ready (this week?) or just the complete sets?
cheers.
Kev.
October 19, 2010 08:18PM
Hello,
The heater block and nozzle threads are m6x1 and are reasonably tight. I am making the nozzle so that the heater block can be screwed all the way against the shoulder. But some thermal compound, on the threads, would help.
I am planning on selling complete sets, on e-bay. However, I'll be happy to sell individual parts via an e-mail.
Regards,
Brian
KmE Wrote:
> Hi Brian,
> heat?
> complete sets?
> cheers.
> Kev.
October 19, 2010 10:19PM
These look really neat. I will be in the market shortly so I will PM when I am ready.
