E3d Heater Block Cleaning
Posted by gmckee
January 25, 2016 02:53PM
Unfortunately I have a bit of a mess on my hands after having a filament leak from my Lite6 that resulted in a heater block covered in PLA. Are there any know ways to dissolve PLA out of the threads. With my crappy knock off hotend would jam I would heat it with the propane torch and burn it out but would rather not do that with the E3d. I believe it is stainless steel so the heat wouldn't mess with the metal too much.
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
Re: E3d Heater Block Cleaning
January 26, 2016 08:26AM
I read somewhere that Chloroform dissolves PLA, same as Acetone does fro ABS.
Just remember, it is only to be used on PLA!
January 26, 2016 08:40AM
I sometimes run an m6 tap through a heaterblock to clean the threads.
January 26, 2016 08:55AM
I have used this stuff to loosen up and dissolve PLA. I let it soak for a few days and it does a pretty good job. Be sure to use proper safety procedures when using this stuff. I can be nasty. If I remember correctly, it is the Dichloromethane {Methylene chloride) that is a solvent for PLA.
[www.homedepot.com]
Edited 1 time(s). Last edit at 01/26/2016 08:55AM by ElmoC.
