sketchup to stl converter (not the plug in)
January 26, 2016 10:04AM
im sitting here on a work computer where I cant install sketchup and load the export plug in. Is there any other skp to stl converter that works?
Cheers
Re: sketchup to stl converter (not the plug in)
January 26, 2016 12:48PM
In newer versions of sketchup you don't need to be admin to install plugins, just copy it to
C:\Users\\AppData\Roaming\SketchUp\SketchUp [n]\SketchUp\Plugins
January 26, 2016 12:55PM
I cant install sketchup at all. but i figured out that fusion360 can handle skp files as well. but the file is too big for fusion to handle it anyway and the pc crashed while trying. so ill asked for a stl file directly.
but nevertheless it would be good to have a converter like this
January 26, 2016 01:22PM
I am not sure sketchup can run without install, like copying the whole folder from another machine but that would be the best alternative, maybe a sketchup portable?. As far as online converters I don't know any good for that task :/
Edited 1 time(s). Last edit at 01/26/2016 01:23PM by eried.
January 26, 2016 01:25PM
i looked as well but none seemed to have it. and then there is also the version difference between the old and the new sketchup files which further complicates working with sketchup
