Re: This engineer claims 100 grams direct extruder. I want one February 16, 2016 10:00AM |
Re: This engineer claims 100 grams direct extruder. I want one February 22, 2016 12:46PM |
Re: This engineer claims 100 grams direct extruder. I want one February 24, 2016 04:06AM |
Re: This engineer claims 100 grams direct extruder. I want one February 24, 2016 05:14AM |
Re: This engineer claims 100 grams direct extruder. I want one February 25, 2016 03:55PM |
Re: This engineer claims 100 grams direct extruder. I want one February 25, 2016 04:25PM |
Re: This engineer claims 100 grams direct extruder. I want one February 25, 2016 05:47PM |
Re: This engineer claims 100 grams direct extruder. I want one February 26, 2016 04:17AM |
Re: This engineer claims 100 grams direct extruder. I want one February 26, 2016 06:35AM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 05:08AM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 06:30AM |
n8bot
I got my cold end down to 310g. Nema11 with 5:1 planetary gb mated to an ezstruder. Works great, even with .25mm nozzle.
[imgur.com]
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 01:18PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 01:29PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 02:18PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 02:27PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 04:13PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 04:33PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 04:35PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 05:22PM |
n8bot
I do have a shorter nema11, also with a 5:1, but the gearbox had a rough spot in it and the motor would stall at that point, even at full current. It likely would work marginally well, but probably not since it hiccupped on the rough spot on the gearbox with a .4mm nozzle. with a .25mm nozzle it might not be great, as this longer one is borderline for .25mm nozzle.
The main reason for nema11 was form factor, yes. I don't think I could fit a larger form factor between the magnets.
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 05:40PM |
Koko76
Once I've worked through a few things a cycloid is going to be built and integrated into the block I'm currently using as a heatsink and extruder. Cycloid will be in the 9-15 to 1 range I think.
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 06:26PM |
realthor
Koko76
Will you be printing the cycloid or do you have the means to machine it. It shouldn't be complicated to machine the real challenge is to get access to a machine and somebody with knowledge to do it. I don't exaclty know if a cycloid would wear and which parts are more prone to wearing maybe (if any) only a few parts need to be machined.
I am thinking at some point at 3d printed parts (cycloidal gears) 1-2mm smaller than a 3d printed mold, then pour some tough resin to fill the gap for the contact surfaces to be as strong as possible. The cycloidal gears have almost zero backlash which is always a nice thing.
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 06:39PM |
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 06:52PM |
Koko76
I have "the means" to machine it. Those parts are unsuitable to be made with general 3d printers available today in order to have the claimed "zero backlash".
thefrog
Don't know if this got linked already ...
My extruder is down to 160g with steel gears and the Sanyo Denki Nema 17 Motor
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 06:55PM |
Realthor
But could we have a section in the reprap wiki or on instructables or even on github -if suitable- where these solutions could have a home so we all could pick one and order the parts and replicate it and report back and the process of improvement would go on?
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 07:01PM |
Luck has little to do with it, years of hard work and research. Not planning on spending a lot of time documenting it, possibly some pics of the completed assembly. Don't use OpenSCAD, I have better tools available, several designs completed just have to finish some numbers and get some free time.Quote
realthor
Koko76
That is indeed lucky of you. I will be following with great interest your project should you be documenting it online. I might have the "luxury" to get the parts machined in my home country for a beer but here in Finland I wouldn't dare ask a quote from somebody for such a job. Do you have anything started yet for the cycloid drive? Will you be using some openscad libraries or will it be a personal project that you will calculate/design yourself?
thefrog
I linked the youtube video on the first page, but this discussion on ultimaker forums is an interesting addition. Thanks. BTW, is this yours?
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 07:10PM |
realthor
Koko76
thefrog
Re: This engineer claims 100 grams direct extruder. I want one February 28, 2016 07:53PM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 12:16AM |
thefrog
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 01:37AM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 02:27AM |
