Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 02:41AM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 03:24AM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 04:01AM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 04:25AM |
to3dornottobe
@Chri; i received mine as well, it's tiny, right? And light.. Mine weighs 48.21 grams. I too think the NEMA8 is too weak. I'm going to make my design so that it also could fit the larger version of the NEMA14 you suggested.
Look at the info Chris shared, nema 8 50 grams, 1.25Ncm holding torque. Nema 14 pancake 50 gram and 7Ncm of holding torque
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 04:32AM |
to3dornottobe
@realthor; Yes, i've thought about that as well. The sliding gear is the challange, this is why. The torque-rod part is too thin, it will bend badly when the carriage is far away from the E motor.
to3dornottobe
What would work if you use an endless belt and a gear (driven on 1 side) and a stationary E motor , cancel out the X motion in the firmware and use the difference compared to the E motion. Needless to say, acceleration and jerk should be taken into account as well. or you'll end up with unwanted extrusion behaviour It could work for CoreXY too, but i don't know if the computing power is available for these calculations?
to3dornottobe
Status of the lightweight NEMA 14 extruder; I'm currently putting down the concept on the back of a napkin, prior to the CAD work.. I'll shoot a picture to share the general idea. Cooling the nema 14 is mandatory, i think.
About the 'dead weight' with a stepper it's not the aluminium that weighs the most; it's the copper, metal and magnets that make it heavy.
The superslim pancape nema17 of sanyo denki weights 70g.
Weight to power ratio of the pancakes is way better than the 'standard' nema 8 and 14 motors.
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 04:43AM |
It`s Chri, not Chris
No, that's not what I meant. You could use the motor stationary as well and have the X/Y motion cancelled out and interpreted in the XY motion when extrusion movement is needed. But at high speeds that design it's pretty worthless, and high speeds is the main reason for lowering the weight of the moving x/y part because you need a VERY fast E motor.. (And another downside is you need to have a serious reduction, otherwise you will have a torque-twist going on in your X/Y motion when the extruder kicks in this could be overcome with the use of a differential on the moving part though, but that requires 2 stationary (non moving) motors for E and 4 for a double extruder.. Then they only need to move when extruder needs action..Quote
It doesn't sound very good. On a corexy you'd have to add extra weight on the Y carriage,
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 05:01AM |
to3dornottobe
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 05:26AM |
I am really interested in where this is going, the Nema14 looks very promising for a good solution. Can't wait to see the CAD.
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 06:44AM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 06:58AM |
to3dornottobe
I've just finished putting the lightweight nema14 in cad (rough drawing, haven't taken it apart for exact bearing sizes etc) it's size accurate to suit my needs. Began on drawing the motor plate, for now with adjustable gear mesh enabling a large variety of spurs/pinions, Thinking about making a generic solution for using different makes/brands of spur gears (an adjustable holder using M3 screws). I do have got the e3d v6 drawing from another project i can use. Have got a plan for the extruders tension. (a U shape that covers the bearing and with pressure at the centre of the bearing)I'm using 5x11x4 bearings to hold the spur in place along with the drive-gear, the bearing that's used for pressure is the standard 625zz or a variant with 6mm hole instead of 5). I think disk springs might be excellent for this task. Small movement, low profile. Only need a clever quick release, without adding too much parts. Some progress has been made.
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 08:59AM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 10:04AM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 02:16PM |
n8bot
thefrog
Don't know if this got linked already ...
My extruder is down to 160g with steel gears and the Sanyo Denki Nema 17 Motor
That pancake extruder is amazing. I bet that would fit on my delta effector. Does it have enough force to push filament through a .25mm nozzle? Where did you source the motor/what are the specs?
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 02:41PM |
to3dornottobe
this is the used motor.
A cyclodial gearing might look easy, but it's rather complex/expensive? in terms of bearings/sliderpins. If anyone needs some machined, i have access to a neat little homegrown machineshop. I do think that traditional 48p gears might cut it, and they cost only about 5usd a set when bought in small quantities.
@thefrog; is 160gram the total weight of your carriage? Extruder itself should be lighter? And it seems that you are using 64p gears?
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 03:09PM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 03:36PM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 04:01PM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 04:24PM |
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 04:44PM |
I want to redesign the E3D to a radial fan and smaller heatsink anyway though.
Re: This engineer claims 100 grams direct extruder. I want one February 29, 2016 05:38PM |
Re: This engineer claims 100 grams direct extruder. I want one March 03, 2016 10:47PM |
Re: This engineer claims 100 grams direct extruder. I want one March 03, 2016 10:52PM |
thefrog
n8bot
thefrog
It has 0,383 N with the 13/60 gearing. That should be sufficient.
Re: This engineer claims 100 grams direct extruder. I want one March 04, 2016 04:34AM |
Re: This engineer claims 100 grams direct extruder. I want one March 05, 2016 03:01AM |
Re: This engineer claims 100 grams direct extruder. I want one March 06, 2016 09:01AM |
Re: This engineer claims 100 grams direct extruder. I want one March 06, 2016 10:10AM |
Re: This engineer claims 100 grams direct extruder. I want one March 10, 2016 08:41AM |
Re: This engineer claims 100 grams direct extruder. I want one March 10, 2016 09:27AM |
Re: This engineer claims 100 grams direct extruder. I want one March 10, 2016 10:16AM |
amigob
you have the round nema 14 also in a 12 Nm version 100 grams, still 40 grams lighter then the one below and 80 grams lighter then the one you came with
One remark : these are not a drop in replacement fr normal NEMA 14's )
and if you want the normal Nema 14 then this is better
[eu.stepperonline.com]
40 grams lighter , same torque and cheaper and they chip also from Germany
Re: This engineer claims 100 grams direct extruder. I want one March 10, 2016 10:44AM |
