Re: This engineer claims 100 grams direct extruder. I want one March 10, 2016 11:05AM |
Re: This engineer claims 100 grams direct extruder. I want one March 10, 2016 02:57PM |
Re: This engineer claims 100 grams direct extruder. I want one March 12, 2016 04:19AM |
Re: This engineer claims 100 grams direct extruder. I want one March 12, 2016 06:00AM |
Re: This engineer claims 100 grams direct extruder. I want one March 12, 2016 06:25AM |
Re: This engineer claims 100 grams direct extruder. I want one March 12, 2016 10:50AM |
But that's not how things work in the real world, especially when you have small motions commanded or to put it another way, when the backlash amount is proportionally high compared to the motion size commanded. Do a little math on some fine layer heights with small features, and a bunch of retracts and you'll see motion sizes that get swallowed in backlash easily. It's best to mechanically eliminate as much as possible.Quote
JamesK
Backlash shouldn't be an issue as you're not interested in details of the motion of the filament during reversal, only in it's final position. Any backlash is factored into the retraction distance, and since the real work of extrusion is always done in the same direction backlash doesn't factor in. The problem with large gear ratios on the extruder is that you limit the retraction speed and acceleration that can be used. For 'easy' plastics like abs and pla it's probably not much of an issue, but for some of the more tricky ones like nylon it might be.
Re: This engineer claims 100 grams direct extruder. I want one March 12, 2016 11:50AM |
Re: This engineer claims 100 grams direct extruder. I want one March 12, 2016 11:55AM |
Can't argue with that, but I didn't follow the rest of your argument. The retraction distance is independent of layer height, and tuned by trial and error. If there is backlash you will use a longer retraction distance to compensate, without ever having to know what the backlash was.Quote
Koko76
to3dornottobe
integrate that with a 5mm aluminium shaft for the MK8
Re: This engineer claims 100 grams direct extruder. I want one March 12, 2016 01:11PM |
Re: This engineer claims 100 grams direct extruder. I want one March 13, 2016 04:03PM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 02:53AM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 03:29AM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 07:49AM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 06:14PM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 06:52PM |
Typically one of the 3xxx series, otherwise known as "gummy, useless garbage".Quote
JamesK
to3dornottobe
It depends, 7075 T6 is pretty tough.
Ooh yeah, that's some nice stuff. I only have 6061 and whatever the dubious stuff from homedepot and lowes is.
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 06:55PM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 07:49PM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 08:56PM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 09:27PM |
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 10:33PM |
There are online calcs to work out motor torque required to accelerate a given mass, that is a good place to start. [orientalmotor.com] has one on it's front page. There are others that one can find with a bit of digging.Quote
JamesK
Ah, sorry, I completely missed the bit about X & Y. No idea how people work those out other than by trial and error. I don't think there's any particular need to use the same motors on X & Y, so I think you're free to use what ever works/fits best.
Re: This engineer claims 100 grams direct extruder. I want one March 14, 2016 11:08PM |
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 04:34AM |
Mutley3D
o_lampe
How much weight would we spare with aluminum-wires for the stepper coils?
LOL
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 06:54AM |
o_lampe
Mutley3D
o_lampe
LOL
There were times, where aluminum wire was a valid replacement for copper in a lot of different electrical equipment. It has a higher resistance, but a stepper that is "overvolted" 2-4 times can cope with that, I'd say.
Aluminum is 3.3 times lighter than copper, but only has a 1.6 times higher resistance. So, why not think it over?
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 06:59AM |
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 07:22AM |
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 07:44AM |
realthor
I believe everybody got it and it was pretty amusing in fact. It's our "defect" to always try to think out of the box and that's why the craziest ideas sometimes begin as a joke...so why diesmiss it .
It would be much more interesting to find a dimensionally stable alternative to the case of the motor, that's where another big chink of its weight goes. But the same thinking goes for that: if it's not mass produced the costs would be prohibitive.
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 07:53AM |
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 08:15AM |
Mutley3D
Please do not misunderstand me, I am not and never will be here to mock anyones ideas. I am however a realist rather than idealist. Some ideas warrant investigation and follow up, others are best left in the stable. Experience lends the capacity to differentiate between ideal and real. The biggest gains are the ones to follow. A few grammes saved which in reality would cost thousands to implement is not a big gain, nor a feasible one to attain. I do however understand a few grammes here, and a few grammes there, can quickly add up.
Yes reducing motor-can weight would be a big benefit, but there are heavy magnets aswell, and the lighter the magnet the weaker the motor, which in turn require the use of gears which may counter any weight savings. Swings and roundabouts one might say. I am trying to provoke out of box thinking, there is not much that is "out of the box" in this thread, in my own view. This may sound harsh, but if you analyse the thread content, it is hard to dispute this. Not wanting to sound slightly controversial, it may provoke some serious thought, and perhaps spur a really clever eureka moment, and different path.
FWIW I doubt it is achievable to get much below 160 grammes (including hotend) for the type of single filament extruder being discussed in this thread - ie stepper motor carriage mounted.
I think the bigger picture is being missed (although this thread was about reverse engineering an extruder that no one has seen working based on a short lifetime dc motor).
The biggest gains (and advancement for "reprap") are going to be in achieving lightweight direct drive multi filament systems. Or is reprap simply about single filament systems? As an example, I just finished assembling a proto of a dual direct drive extruder which including hotend, all fasteners and 60% infill comes in at 101grammes.
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 08:18AM |
Re: This engineer claims 100 grams direct extruder. I want one March 15, 2016 08:23AM |
