Re: This engineer claims 100 grams direct extruder. I want one April 19, 2016 03:58AM |
Re: This engineer claims 100 grams direct extruder. I want one April 19, 2016 04:35AM |
Re: This engineer claims 100 grams direct extruder. I want one April 19, 2016 11:19AM |
Re: This engineer claims 100 grams direct extruder. I want one April 20, 2016 03:03PM |
o_lampe
I wonder if the flex3drive would benefit from a cycloidal drive? The worm gears it uses now will sure have a lower efficiency?!
o_lampe
...think of multifeed flex3drive extruders...
Stacking more than two cycloidal extruders is difficult because input and output shaft are inline.
Re: This engineer claims 100 grams direct extruder. I want one April 22, 2016 06:54PM |
powdermetal
jonnycowboy
Powermetal, are your files available?
I'd like to rework it for the NEMA14 two-bolt stepper (50g only - 14HR08-0654S). With your solution we could bring the complete cold/hot end down to 100g combined with the new DeltaMini hot end.
I am planning to put the files to a wiki page here - just in case you want to play with them. This will include parts in STEP-format and simplified parts (no blends/chamfers/...) for easier modification.
The 14HR08-0654S as proposed by Chri and others seems to be a nice lightweight and effective motor solution for such kind of application - maybe another gearbox with a modified ratio (something like 15:1) with this stepper will make it's way...
Regarding precision: Is there anybody, who has access to a precise lasercutter or watercutter, who could cut properly toleranced gears from plastics to see, whether this concept is viable at all?
Re: This engineer claims 100 grams direct extruder. I want one April 22, 2016 07:01PM |
Many thanks! My nema14 extruder with 5:1 ratio is right on the ragged edge for 3mm pla, so I'm looking for alternatives in the 10:1 ballpark. I may end up trying this
Re: This engineer claims 100 grams direct extruder. I want one April 23, 2016 06:51AM |
Re: This engineer claims 100 grams direct extruder. I want one April 23, 2016 03:47PM |
Anonymous User
Re: This engineer claims 100 grams direct extruder. I want one April 24, 2016 01:37PM |
Re: This engineer claims 100 grams direct extruder. I want one April 24, 2016 05:05PM |
Anonymous User
Re: This engineer claims 100 grams direct extruder. I want one April 25, 2016 01:10AM |
Mutley3D
MKSA
a high ratio means high step/turn and this could lead to stalling while retracting the filament.
Complete rubbish! - (OK Perhaps a bit harsh I admit - apologies!) - So, the following may cause some consternation. This is not my objective. I wish to generate thought and debate toward a definitive resolution and understanding for wider community and dispell some myths being purported as fact! There are some over looked fundamentals that need to be revisited! I am possibly deviating from the topic somewhat, but it is directly related to the objective in this thread. Perhaps another thread should take this subject matter further.
Re: This engineer claims 100 grams direct extruder. I want one April 25, 2016 03:32PM |
thefrog
Don't know if this got linked already ...
My extruder is down to 160g with steel gears and the Sanyo Denki Nema 17 Motor
Re: This engineer claims 100 grams direct extruder. I want one April 25, 2016 05:44PM |
powdermetal
There seem to be more designs using the Sanyo Denki Nema 17 Motor: Ultimaker 2 pancake stepper direct drive
Just a very small direct driven knurled shaft...
Anonymous User
Re: This engineer claims 100 grams direct extruder. I want one April 26, 2016 02:04AM |
powdermetal
thefrog
Re: This engineer claims 100 grams direct extruder. I want one April 26, 2016 03:39AM |
MKSA
The hobbed gear is really small, not well designed.
Re: This engineer claims 100 grams direct extruder. I want one April 26, 2016 06:47AM |
Anonymous User
Re: This engineer claims 100 grams direct extruder. I want one April 26, 2016 11:13AM |
Re: This engineer claims 100 grams direct extruder. I want one April 29, 2016 03:08PM |
Re: This engineer claims 100 grams direct extruder. I want one April 29, 2016 11:52PM |
Re: This engineer claims 100 grams direct extruder. I want one April 30, 2016 03:07AM |
toxuin
Is there a drop-in translation electronics to use heavy geared dc motor instead of a stepper? I have a couple of small and light DC motors with planetary gearbox strapped to them. Would gladly try them out as a candidate for "less weight more speed".
If I remember correct, DC motors have a decent torque at low speed. This makes them a perfect candidate for use in an extruder motor. Also, I believe Stratasys uses rather small DC motors in their extruders. The reason RepRaps use steppers instead of DC is the complexity of the control electronics. In fact, first reprap extruders were DC, but had trouble with control and calibration. I wish we could go back and reverse that change towards steppers: maybe at the time it was reasonable – after all there were no accessible fast microcontrollers to do the closed-loop control, but now there are plenty of them.
So ,from time to time I read some news about the DC motor based closed-loop control, but there is no code or it is very specific to the application. I wish there would be a board with a tiny 8-bit controller, an H-bridge and a rotary encoder sensor that would basically accept the step signals and translate it to DC motor language.
Re: This engineer claims 100 grams direct extruder. I want one April 30, 2016 03:21AM |
Re: This engineer claims 100 grams direct extruder. I want one April 30, 2016 04:08AM |
o_lampe
Wouldn't it be easier to use 3-phase brushless DC motors without encoders?
They are used in "brushless camera gimbals" with a L6234D 3-phase stepper controller chip ( 5A max current!)
The motors are available in many sizes and have more torque/weight than classic steppers because they are outrunners and have an inbuilt magnetic 7:1 gear reduction by design.
Re: This engineer claims 100 grams direct extruder. I want one April 30, 2016 07:18AM |
toxuin
Re: This engineer claims 100 grams direct extruder. I want one May 05, 2016 06:11AM |
Re: This engineer claims 100 grams direct extruder. I want one May 05, 2016 06:45PM |
JamesK
Re: This engineer claims 100 grams direct extruder. I want one May 05, 2016 06:51PM |
powdermetal
The Cycloidal Extruder Drive has been updated with a 16:1 ratio to engage the proposed lightweight NEMA14 pancake stepper 14HR08-0654S (7Ncm, 50g). This did work fine until the heat from the stepper made the PLA-components start to creep - will be resolved soon...
Re: This engineer claims 100 grams direct extruder. I want one May 05, 2016 06:57PM |
powdermetal
Re: This engineer claims 100 grams direct extruder. I want one May 06, 2016 02:09AM |
Re: This engineer claims 100 grams direct extruder. I want one May 06, 2016 03:27AM |
ipcalit
The Nscrypt above seems to be using a worm and DC motor. Initial Reprap design used a screw to drive the filament directly, but the filament twists while advancing in response to the rotation of the screw. More recent attempts use two counter rotating screws but I haven't seen any good results yet.
Here is another idea inspired by these two:
1) thread the shaft of a tiny stepper (1-2Ncm is probably enough, <50g) with something between an M3-M5
2) make grooves with the corresponding tap (M3-M5) into the outside of a small bearing (e.g, 623, 624)
3) use the resulting screw shaft of the stepper to drive directly the bearing as a worm gear using another similar bearing as idler on the opposite side, something along the lines of (beware ASCII art)
o|O/
where o = idler, | = filament, O = grooved bearing, / = stepper shaft.
This way, you get the reduction advantage of the worm drive without twisting filament. Bonus: groove cleaning is built-in. The stepper could have 7.5deg steps or be driven with 1/2 micro stepping to achieve higher rpms for retraction.
Re: This engineer claims 100 grams direct extruder. I want one May 06, 2016 04:05AM |
