This engineer claims 100 grams direct extruder. I want onesmiling smiley
Posted by realthor
Re: This engineer claims 100 grams direct extruder. I want onesmiling smiley
August 06, 2016 06:52AM
I'm using acceleration of 2000mm/sec^2 and 2mm retraction at 40mm/s. This works fine, despite your doubts. But it's still stringy...
IIRC, dc42 claims 15000Hz for the Due_RRF firmware for steps, so I tried 60mm/s retraction with occasionally failure ( 1 out of 20 )
It usually was the extrusion part after a successful retraction.
I'm willing to try your "lame" settings, maybe I get a nice surprise grinning smiley
-Olaf
BTW, the RAPS128 drivers at 16/1 microsteps can keep the stepper much colder than the A4988. I guess it's the faster current control loop?
August 06, 2016 07:03AM
dc42
What is the inductance of your Nema 11 motor? Can you get a variant that has a higher rated current but lower inductance?
My apologies, it is of course the NEMA14 like it's supposed to be with 7.5 mH. There is a slightly bigger and heavier NEMA14 pancake with 5 mH available, but the longer housing would reduce the deltas bed radius even more. ( collision with the rods at some places)
August 06, 2016 09:44AM
We're getting there! smiling smiley
The suggestion to use less retraction length and speed helped a lot against stringing. But the blobs got worse...
I tried it one more time with 1mm retraction at 30mm/s, but the blobs didn't disappear.
If I find the time today I'll try 1.5mm at 35mm/s. There must be a sweet spot, still undiscovered.
open | download - blobs_vs_strings2.jpg (186.5 KB)
August 06, 2016 10:03AM
o_lampe
The dodecahedron was printed at 60mm/s & travel at 150mm/s. I thought, the faster travel the less stringing.
That has also been my experience. I can't see anything in your settings that looks questionable at all, everything seems within the ballpark of where I would have put it.
I'm glad to see that you're getting closer to a good set of numbers. I bet it's frustrating to trial something that, at first glance, should give amazing prints, but it doesn't perform as well as expected. Good luck with the tuning.
Edited 1 time(s). Last edit at 08/06/2016 10:03AM by nebbian.
August 06, 2016 10:43AM
o_lampe
15kHz is the step rate at which the firmware switches to double stepping. The maximum step rate with just one motor moving is about 300kHz on the Duet Wifi, using firmware 1.15 beta. On the Duet it is probably about 200kHz.
o_lampe
It's much more likely that they are cooler because you are running them at a lower current.
August 06, 2016 03:54PM
o_lampe
Good to hear - seems to get better!
E3D's docs says:
E3D
Excessively long retractions will cause issues by dragging soft filament into cold areas. E3D-v6 hotends need less retraction than most hotends. For direct extrusion systems you should use anywhere from 0.5mm-1.0mm, for bowden systems you might want to go up to 2mm. Retraction beyond 2mm is likely to cause issues.
Not sure, but maybe the severe blobs are caused by air being sucked into the hotend during retract, mixed inside to a nice foam and then extruded onto the print. I'd suggest to start from retract=0 upwards and see, how the stringing and the blobs behave.
Edited 1 time(s). Last edit at 08/06/2016 03:54PM by powdermetal.
August 07, 2016 02:20AM
nebbian
I was calling for trouble when I started testing a brand new extruder on an uncalibrated delta, so I partly expected to waste a full spool of filament for tuning.
Maybe it was all false alarm: I noticed the blobs mostly appeared on the lee-side of my part cooler. When I placed another fan there, the print got much better.
dc42
I tested the extruder on a RAMPS with the ramps-test code.
The A4988 was set to 0.26V which is 0.32A and the stepper got too hot to touch. ( Crappy ramps-test code? )
Now it runs at 0.52A and stays cool with the RAPS128.
October 03, 2016 12:22PM
Ping.........!
Anybody advanced any further with this project?
I heavily modified the casing drawings to arrive at something suitable for my Kossel where the E3d hangs underneath the spider but a load of other diversions mean that I don't yet have a fully operational unit - but I am interested to hear how others are getting along.
Having recently moved house, my workshop is slowly getting back to being operational again (the 03D stuff sits in the office!), and this included a CNC mill and lathe which I intend to use to try some of the components in aluminium - especially the outer gear casing and probably the pin carrier and shaft. Update will follow when I get somewhere closer!
Regards,
Simon
October 04, 2016 04:16PM
Simon0362
Ping.........!
Regards,
Simon
We have hijacked this thread for quite a while with this thing and I just gave the discussion it's own home - please proceed to the dedicated Cycloidal Extruder Drive thread - see you there...
October 05, 2016 05:00PM
I have followed with great interest the whole thread and this is exactly what I was after: a concept that would crystallize into something real. I am a big fan of the cycloidal drive so this is so much more interesting to me.
While I hope this thread will continue to have folks show off their lightweight extruders concepts and prototypes, I am glad that your design got a well deserved new home.
RepRap Lander concept on Concept Forge
RepRap Lander concept on RepRap Forums
My Things, mostly experimental stuff
