Tinyboy Fabrikator no longer connects to PC January 29, 2016 02:08PM |
Re: Tinyboy Fabrikator no longer connects to PC January 30, 2016 09:11AM |
Re: Tinyboy Fabrikator no longer connects to PC January 30, 2016 10:12AM |
Device Descriptor: bcdUSB: 0x0200 bDeviceClass: 0x00 bDeviceSubClass: 0x00 bDeviceProtocol: 0x00 bMaxPacketSize0: 0x08 (8) idVendor: 0x0403 (Future Technology Devices International Limited) idProduct: 0x6001 bcdDevice: 0x0600 iManufacturer: 0x01 0x0409: "FTDI" iProduct: 0x02 0x0409: "FT232R USB UART" 0x0409: "FT232R USB UART" iSerialNumber: 0x03 0x0409: "A9SFNTHH" bNumConfigurations: 0x01 ConnectionStatus: DeviceConnected Current Config Value: 0x01 Device Bus Speed: Full Device Address: 0x01 Open Pipes: 2 Endpoint Descriptor: bEndpointAddress: 0x81 IN Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Endpoint Descriptor: bEndpointAddress: 0x02 OUT Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Configuration Descriptor: wTotalLength: 0x0020 bNumInterfaces: 0x01 bConfigurationValue: 0x01 iConfiguration: 0x00 bmAttributes: 0xA0 (Bus Powered Remote Wakeup) MaxPower: 0x2D (90 Ma) Interface Descriptor: bInterfaceNumber: 0x00 bAlternateSetting: 0x00 bNumEndpoints: 0x02 bInterfaceClass: 0xFF bInterfaceSubClass: 0xFF bInterfaceProtocol: 0xFF iInterface: 0x02 0x0409: "FT232R USB UART" 0x0409: "FT232R USB UART" Endpoint Descriptor: bEndpointAddress: 0x81 IN Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00 Endpoint Descriptor: bEndpointAddress: 0x02 OUT Transfer Type: Bulk wMaxPacketSize: 0x0040 (64) bInterval: 0x00
Re: Tinyboy Fabrikator no longer connects to PC January 30, 2016 10:14AM |
Re: Tinyboy Fabrikator no longer connects to PC January 30, 2016 10:27AM |
Re: Tinyboy Fabrikator no longer connects to PC January 30, 2016 02:49PM |
Re: Tinyboy Fabrikator no longer connects to PC January 30, 2016 03:23PM |
Re: Tinyboy Fabrikator no longer connects to PC January 31, 2016 08:18AM |
Dust
The latest windows driver no longer bricks clone FTDI chips, but does detect its a clone and will not fuction..
People are reporting "The Arduino IDE's serial monitor reports: "NON GENUINE DEVICE FOUND" printed over and over again! "
You need to roll the driver back to a pre nasty version..
or run linux
or plug your controller into a raspberry pi running octoprint (so windows can't see the FTDI chip)
or get a non clone FTDI chip (though after all FTDI's nastiness I advise using a ch340 or alternative usb to serial converter.)
Re: Tinyboy Fabrikator no longer connects to PC February 02, 2016 02:40PM |
