Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 02, 2016 04:54PM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 02, 2016 05:04PM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 02, 2016 05:20PM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 02, 2016 05:38PM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 02, 2016 05:54PM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 02, 2016 08:51PM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 01:48AM |
JamesK
Very nice! These have been a very thought provoking pair of threads.
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 04:29AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 05:01AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 05:07AM |
Moriquendi
I think we'll be able to print a reliable renishaw probe long before we can print FSRs
Moriquendi
I tried lever amplification using switches under the print bed and I found that it wasn't helpful, the flex and slop in the lever system far outweighed the advantages.
Yes I think the piercing gold-plated idea from the link above has some potential.Quote
Moriquendi
I think when I rebuild it I will use gold plated contacts, gold doesn't tarnish, is low resistance and easy to solder to. Stainless steel is not easy to solder.
Moriquendi
Ps. I don't mean to dismiss anyone's ideas, I'm all for trying things out for yourself. One of the beauties of having a 3d printer is that you can test new ideas quickly and cheaply. I'm just sharing my experience and thought's, your mileage may vary.
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 05:26AM |
leadinglights
Hi Moriquendi, just a quick note re. soldering stainless steel. If you use something called Phosphoric acid as a flux you will find that stainless steel is about the easiest and most satisfying material to solder.The amount used is tiny - I use one end of a matchstick to dab a bit on the stainless steel then bring a normal temperature soldering iron and normal (60/40) solder to the bit to be tinned at the same time - the solder will flow easily across the surface. Phosphoric acid itself is fairly innocuous, even having a 'E' food number - E338. Having said that, avoid breathing the fumes when soldering as doing this too much will cause your jaw to fall off (see phossy jaw)
Mike
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 06:15AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 06:36AM |
lyscanthrope
I'm sorry to intrude in the topic ....
i'm having another "probeless" that I would like to investigate ...and not sure if it will be a viable solution.
I have seen some people doing it and a lot a people that don't like it
The idea will be to detect when the hotend tip touch the build plate (I'm currently having an aluminium bed).
I think that idea is pretty nice and going down slowly might not damage the bed :
The "not so good ideas" are :
- melted pla could isulate the tip. But according to someone in thingiverse it isn't so bad as the soft pla squished when pressing down
- If one the wire comes out of the bed ...it could crash in the bed ...well ...I think it true for most system ! The problem is that welding on the bed isn't reaaly easy
- putting directly a circuit loop on the hotend and the bed can have some bad effect on your electronics (in case of short circuit with other elements)
I totaly agree with the later one and I think, if tried, it should be done using an isolated circuit for the hotend-bed in order to avoid shortcircuit !
What do you think ?
I'm planning to add a aluminium plate coated with PEI ....I don't known if it will be condutctive enough and if the hotend will not damage the PEI coating ...
PS : attached is the schematic I plan
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 06:50AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 06:56AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 07:36AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 07:44AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 07:50AM |
JamesK
Looks good, except I'd lose the pointy tip and go round to minimize any bed damage. It would be nice if we could do without any extra stuff that would have to be positioned on the bed if possible though. I know touching the nozzle to the bed feels like a bad idea, but I think for the contact forces and durations we're talking about, both the tip and the bed are probably more than robust enough to cope.
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 07:55AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:06AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:08AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:17AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:20AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:27AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:40AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:42AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:45AM |
Moriquendi
I love the simplicity of probing the bed electrically with the nozzle but I just don't think it's feasible. I don't know anyone using a bare metal print bed and I know that my nozzles get mucky pretty quickly even if there isn't any ooze.
One way of tackling it might be to remote sense a coil (the bed heater perhaps) using the nozzle as a pickup in the same way that live wire detectors work. I don't know how high a voltage you would need nor how accurate it would be but you could relatively easily inject a signal into the bed heater and look for it using the nozzle even through glass.
If your probe works in an active-when-the-circuits-open manner then losing a wire won't crash the bed. All that happens is that as soon as the firmware looks at the probe it thinks it's triggered and records that as the probe point, you don't get a reading bu there's no damage.
Moriquendi
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 08:56AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 09:01AM |
Re: Using FSR at hotend level for an unoptrusive bed probing via the nozzle February 03, 2016 09:32AM |
Moriquendi
Sorry, a lot got posted while I was typing my last post, I'm still digesting what you're suggesting realthor, I was talking about direct electrical probing of a conductive bed with the nozzle.
I don't know about dragging a probe around the bed with the nozzle. Once I've got abs juice from a couple of prints on the bed it's too rough to drag a probe around on.
I think Lyscanthrope is thinking that the springs would be printed PLA.
Moriquendi
