Hi guys i have A prusa I3 i recently rebuild it to arduino mega with ramps 1.4 and added A inductive sensor for auto leveling. Everything finally works in the beginning it had problems with printing in the center of my bed. But thanks to you here i fixed it. But now i have another problem.
When my print is finished X and Y needs to home as set in slicer. It does this, but after homing X and Y go to the middle of there max distance and then Z goes down so when i have A print of 100mm in height or so my extruder will crash into my print. Also when i set park postion it does the same. What can cause the problem of this? Also when i home X and then Z and i want to move manually it goes straight to the middle of the bed (X and Y) and then i cant move it manually.. Cant find the problem can you help?
