Trigger Relay with Extruder Stepper Driver
Posted by vulcanrd
February 19, 2016 03:04PM
Is there a way that a relay can be triggered only when the stepper driver is moving in a positive direction, ie can I turn on a fan only when the extruder is extruding and turn it off when its retracting?
Re: Trigger Relay with Extruder Stepper Driver
February 19, 2016 03:32PM
The M571 command does this (see [reprap.org]), but AFAIK the only firmware that supports it is RepRapFirmware.
February 19, 2016 10:28PM
You could tap off the direction pin on the driver board, that might do what you want. You'd have to add a transistor / FET / op-amp or similar power amplifying device though.
Edited 1 time(s). Last edit at 02/19/2016 10:28PM by nebbian.
