MFA Tube Max Temperature February 20, 2016 09:28AM |
Re: MFA Tube Max Temperature February 20, 2016 10:11AM |
Re: MFA Tube Max Temperature February 20, 2016 10:27AM |
Re: MFA Tube Max Temperature February 20, 2016 10:31AM |
Re: MFA Tube Max Temperature February 22, 2016 01:57PM |
Re: MFA Tube Max Temperature February 22, 2016 09:18PM |
Re: MFA Tube Max Temperature February 23, 2016 02:56AM |
Re: MFA Tube Max Temperature February 23, 2016 07:00AM |
Re: MFA Tube Max Temperature February 23, 2016 11:34AM |
Masterjuggler
That's continuous service temperature, and doesn't even show how it was tested or calculated, so I ignored it entirely. Like I said, I printed at 250C for several hours, and though that may not have been long enough to be conclusive, it certainly worked without any problems or damage to the tube.
Masterjuggler
The actual working temperature for printing should be higher than stated because those are (AFAIK) with safety margins, and are most likely the temperatures when the material begins to lose it's mechanical properties, not the temperatures it would need to be at to begin to fail at a given task.
So I'm asking: Does anyone actually know anything else about this?
