One of the neat things about these systems is that they're completely configurable. You can use whatever settings you want for whatever reason you want.
I've been known to modify my standard profiles with a lower bed temperature if a given printer has a heated bed that struggles and the printed part is small enough not to need the usual temperature.
A slight boost to the extruder temperature might help layer bonding on a taller part (or not).
Large parts also might nudge you in the direction of sacrificing some quality in exchange for faster printing...Taller layers, faster speeds, sparser infill, less complex infill patterns, etc.
