Best Sensor for ABL February 24, 2016 01:29AM |
Re: Best Sensor for ABL February 24, 2016 03:52AM |
Re: Best Sensor for ABL February 24, 2016 03:54AM |
Re: Best Sensor for ABL February 24, 2016 09:44AM |
Re: Best Sensor for ABL February 24, 2016 10:44AM |
Re: Best Sensor for ABL February 24, 2016 11:05AM |
Re: Best Sensor for ABL February 24, 2016 11:07AM |
leadinglights
When tjnamtiw says that the BLTOUCH is stupid simple, light and easy to set up then that is marketing but "End of story" is unhelpful and even plain insulting.
Re: Best Sensor for ABL February 24, 2016 11:10AM |
makerparts
BLTouch looks interesting.
Re: Best Sensor for ABL February 24, 2016 11:23AM |
tjnamtiw
leadinglights
WHAT ARE YOU TALKING ABOUT? Maybe 'stupid simple' doesn't translate well into what ever language you speak but it means it is very easy to understand, connect and use! How can it be insulting? I do not work for the people that make BLTOUCH but I AM a satisfied customer and I just answered the question as to viable options for bed leveling.
END OF STORY means that IMHO there can't be a simpler solution for the OP's situation. I realize that you have been on here 4 years and delight in testing the most obscure solutions but apparently you don't want to consider that there are very simple, workable solutions to the problem.
I suggest you have an appointment with a psychiatrist! I AM THE ONE INSULTED!
Re: Best Sensor for ABL February 24, 2016 11:25AM |
leadinglights
Re: Best Sensor for ABL February 24, 2016 11:27AM |
Re: Best Sensor for ABL February 24, 2016 11:39AM |
Re: Best Sensor for ABL February 25, 2016 02:41PM |
Re: Best Sensor for ABL February 27, 2016 10:20AM |
Re: Best Sensor for ABL February 27, 2016 05:41PM |
Re: Best Sensor for ABL February 27, 2016 09:10PM |
Re: Best Sensor for ABL February 28, 2016 05:50AM |
Re: Best Sensor for ABL February 28, 2016 06:21AM |
Re: Best Sensor for ABL February 28, 2016 06:46AM |
Re: Best Sensor for ABL February 28, 2016 06:52AM |
Re: Best Sensor for ABL February 28, 2016 10:42AM |
Re: Best Sensor for ABL February 28, 2016 11:02AM |
Re: Best Sensor for ABL February 28, 2016 01:20PM |
Re: Best Sensor for ABL February 28, 2016 01:54PM |
dc42
May I caution would-be users of bltouch that if used with Arduino/RAMPS electronics, you are likely to burn out the 5V regulator on the Arduino unless you supply external 5V power. Please don't take this as a criticism of bltouch, it is a well-known problem of Arduino/RAMPS that it cannot support enough 5V power to drive servos, graphical LCDs etc. safely. The RAMPS board ought to include a 5V regulator to power additional devices, but it doesn't.
I see that the supplier of bltouch is attempting to protecting it with patents. Is bltouch also closed source? In the spirit of RepRap, my own differential IR sensor is not patent protected, and the schematic and firmware are open source.
Re: Best Sensor for ABL February 28, 2016 07:07PM |
Re: Best Sensor for ABL February 28, 2016 08:31PM |
Re: Best Sensor for ABL February 28, 2016 09:04PM |
Re: Best Sensor for ABL February 28, 2016 09:37PM |
Re: Best Sensor for ABL February 29, 2016 02:23AM |
nebbian
I had high hopes of using an IR sensor, but as I put my bed with PEI surface together before anyone had tried IR + PEI, I didn't paint the bottom black. Now the reflectance is too variable, and I didn't realise that PEI was transparent to IR. A physical touch sensor seems to be the right approach anyway, instead of hoping that the PEI sheet is the same thickness everywhere. At least with a physical sensor you are calibrating against the surface you're trying to print on.
