Re: Best Sensor for ABL February 29, 2016 02:59AM |
dc42
What sort of printer do you have? If it's a delta, you need a sensor that has low mass and can be placed very close to the nozzle.
Re: Best Sensor for ABL February 29, 2016 03:45AM |
nebbian
dc42
Yes, it's a delta (Kossel mini).
Very well, what do you suggest, bearing in mind that I can't use your sensor due to not wanting to remove the existing PEI sheet on my bed?
Re: Best Sensor for ABL February 29, 2016 06:02AM |
Re: Best Sensor for ABL February 29, 2016 12:52PM |
nebbian
Ah right. Correct me if I'm wrong, but all those solutions aren't easy to retrofit to a production printer with minimal downtime.
A BLTouch it is then! Thanks for confirming it
Re: Best Sensor for ABL February 29, 2016 05:34PM |
Re: Best Sensor for ABL February 29, 2016 07:49PM |
Re: Best Sensor for ABL February 29, 2016 10:30PM |
Re: Best Sensor for ABL March 01, 2016 10:48PM |
nebbian
I just asked the seller how heavy the BLTouch is, and the reply was 10 grams.
For interest's sake, I weighed my kossel mini's useless Z probe, including allen key, switch and mounting bolts. 13 grams. And that's for something that is difficult to set up, has poor repeatability, and never really seemed to work properly.
Re: Best Sensor for ABL April 15, 2016 12:21AM |
Re: Best Sensor for ABL April 15, 2016 03:45AM |
Re: Best Sensor for ABL April 15, 2016 06:23AM |
I wouldn't use any system which touches the bed with the hot nozzle. These systems are unsuitable for some print surfaces and also for a dual nozzle setup.
Re: Best Sensor for ABL April 15, 2016 12:42PM |
Treito
I wouldn't use any system which touches the bed with the hot nozzle. These systems are unsuitable for some print surfaces and also for a dual nozzle setup. Capacitve proximity switches may depend on (bed) temperatures and humidity.
BLTouch is not directly supported by my controller board.
I have a similiar optical sensor like the one from PiBot except I get a direct value for a height instead of an on/ off signal. However this system is very bad and differs in height readings nearly every time. It is dependant from the bed surface and temperature for example. If the bed is not preleveled well ABL does not work good with this sensor.
I changed to the Mini height sensor from dc42. This is very accurate and I got similiar settings like a system with direct nozzle touch, but it is touchfree which I prefer.
I will also use one of these boards for my own printer design. However the biggest disadvantage is the price for this part, but at least it is the best option in my eyes.
Re: Best Sensor for ABL April 16, 2016 02:55AM |
JamesK
Hi Treito, what issue do you see with dual nozzles for nozzle-bed contact? The advantage of a direct contact system is that you don't need any additional setup to allow for the nozzle to probe offset. I change hotends a lot so I plan on using a piezo based nozzle-bed contact system specifically so that I don't have to manually re-check my Z=0 calibration after each change, but it's a dual extruder setup and you have me wondering if I have overlooked something.
There is no support with the firmware of the Duet 0.6 and 0.85. As far as I know there is even a problem with the Pin-headers for the 0.6-version.Quote
tjnamtiw
If your board supports a servo style ABL, then it supports the BLTOUCH.
