Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 24, 2016 04:52PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 24, 2016 06:00PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 24, 2016 06:09PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 24, 2016 06:14PM |
Srek
Multiple laminated sheets with impregnation should serve you well.
No idea how it is called in english, but this stuff here
[www.epspoland.de]
[www.epspoland.de]
is pretty much immune to anything but a saw.
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 02:32AM |
Srek
[www.epspoland.de]
[www.epspoland.de]
It's definitely not safe to breathe in dust made from machining it (or MDF in that case), but I can't say it has any smell when just "left alone". I know that's not a scientific way to test it - just a thought.Quote
realthor
Looks interesting. Is it safe to use indoors? At least with aluminum you have no worries health-wise so it's always good advice to check VOCs and other possible hazardous pollutants.
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 04:35AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 05:56AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 06:24AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 07:44AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 08:32AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 08:44AM |
Depending on the exact glues and resins used wood can be even more fireproof than metal. The surface might scorch, but it builds up a non flamable chared buffer the will prevent real burnup. A firend of mine is a carpenter and told me that often carpentry workshops are using wooden beams over metal because of this.Quote
the_digital_dentist
Wood and heat are a bad combo, best avoided.
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 08:53AM |
Srek
the_digital_dentist
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 09:11AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 25, 2016 09:26AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 26, 2016 06:48PM |
Srek
[www.epspoland.de]
[www.epspoland.de]
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 26, 2016 07:08PM |
realthor
is there anything wood still has to offer?
realthor
the transition has been towards more dimensionally stable materials...
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 26, 2016 08:16PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? February 27, 2016 10:08AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 01, 2016 05:03PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 01, 2016 05:09PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 01, 2016 05:23PM |
Srek
They will always fight each other, there are very few lucky combinations where the thermal expension rates of two materials match so well that this works (steel and concrete i.e.).
There are two solutions, either create a flexible connection, or make the panel of elastic material and so thin that it does't exert enough force to warp the frame.
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 01, 2016 05:28PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 02, 2016 12:00PM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 16, 2016 09:13AM |
PerformancePanels.com
Plywood and wood expand upon heating, as do practically all known solids. The thermal expansion of wood, however, is quite small and requires exacting techniques for its measurement. The effect of temperature on plywood dimensions is related to the percentage of panel thickness in plies having grain perpendicular to the direction of expansion or contraction. The average coefficient of linear thermal expansion is about 3.4 x 10-6 inch/inch per degree F for a plywood panel with 60 percent of the plies or less running perpendicular to the face. The coefficient of thermal expansion for panel thickness is approximately 16 x 10-6 inch/inch per degree F.
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 16, 2016 11:38AM |
Re: Wood-based frames: are there processes that can make wood (composites) suitable for 3D printer frames? March 16, 2016 04:26PM |
realthor
How would you account for plastic (3D printed) parts screwed into the wood?
