An idea for increasing the Z-axis strength of printed parts February 24, 2016 09:54PM |
Re: An idea for increasing the Z-axis strength of printed parts February 25, 2016 09:56AM |
Re: An idea for increasing the Z-axis strength of printed parts February 25, 2016 10:10AM |
Re: An idea for increasing the Z-axis strength of printed parts February 25, 2016 08:19PM |
Re: An idea for increasing the Z-axis strength of printed parts February 26, 2016 02:54AM |
Re: An idea for increasing the Z-axis strength of printed parts February 26, 2016 08:00PM |
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 02:28AM |
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 04:25AM |
o_lampe
Why not make the whole part hollow and fill it with 2k-resin afterwards? Would also print much faster.
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 06:11AM |
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 06:26AM |
if you print with 100% infill the part will be very strong. The blog post [e3d-online.com] states I thought that that was just marketing blabla until I printed my first part with the volcano and tried to break it myself.Quote
the tabs on the part printed with a standard 0.40mm nozzle could be broken by hand if you really try. However the same features printed with Volcano were impossible to break with bare hands, and we really tried! Even with pliers we struggled to delaminate the layers.
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 06:30AM |
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 09:49AM |
I did a 0.8 layer, speed was hard to tune, the filament is fed fast so there isn't much time to heat up to a good print temperature. As I said here [forums.reprap.org] "I might be able to push the volcano to 30mm/s, I failed at 35mm/s but it might be that replacing the Wade extruder for a full metal extruder would allow for some more pressure and thus have less issues with the lower plastic extrusion temperature."Quote
MechaBits
So what are the layer heights on the 1.2mm nozzle, I bet print speeds quite nippy.
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 10:01AM |
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 11:14AM |
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 11:18AM |
Re: An idea for increasing the Z-axis strength of printed parts February 27, 2016 05:36PM |
MechaBits
I like the idea of dipping honeycombs in resin(a sweet solution), it has a certain appeal.
Re: An idea for increasing the Z-axis strength of printed parts February 28, 2016 05:31AM |
Re: An idea for increasing the Z-axis strength of printed parts February 28, 2016 10:09PM |
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 04:52AM |
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 05:52AM |
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 05:58AM |
there are some single component epoxies but those are normally much more expensive then the 2 parts. Mixing nozzles will indeed cost around usd1Quote
bdurbrow
That is a possibility... my sticking point with two part epoxies though is that it sets up in the nozzle after the print is done... requiring a disposable nozzle; or some sort of solvent flush system. Not an insurmountable obstacle... but definitely something to be aware of before heading in that direction. They tend to also be somewhat expensive...
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 07:01AM |
Frans@France
Aceton vapor would be dangerous. But I like the idea about using welding. Why not ultrasonic weld the layers? No need for holes but just an extra "extruder" that welds at certain point the layers.
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 08:16AM |
I don't know which is more dangerous, Acetone or ABS particulate...
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 08:43AM |
bdurbrow
Well, do you want to die in a fire now, or of cancer later?
bdurbrow
As for recycling composites; I would suggest considering a pyrolysis process; like this:
[en.wikipedia.org]
Discover magazine had several articles about the process, the first being from 2003:
[discovermagazine.com]
Once converted back to oil, reforming it into new plastic should be rather straightforward (I am not, however, an organic chemist, so my knowledge of the subject is somewhat limited).
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 09:51AM |
Re: An idea for increasing the Z-axis strength of printed parts February 29, 2016 03:17PM |
