any way to turn off the display while keeping USB connected?
Posted by icefire
February 26, 2016 10:05AM
Ramps 1.4 with RepRapDiscount full graphic controller. When I don't use the prineter I turn off the power supply but the display remains on because the ramps/arduino is connected via usb to a always-on pc.
Is there a way to make the display turn itself off when idle? I don't want to ruin the backlight or some pixels over time...
Thanks!
Self-sourced Mendelmax 2.0-based Reprap Machine -- Ramps 1.4 & Mega 2560 -- DRV8825 (Z@1A, [email protected], [email protected], E@1A) -- genuine E3D v6 direct setup -- 350W custom silicone heated bed -- ABS 1,75mm -- Marlin 1.1.0-RC7 -- Cura 15.04.6
Re: any way to turn off the display while keeping USB connected?
February 26, 2016 04:28PM
I just unplug my usb cable...
February 26, 2016 05:43PM
[reprap.org] suggest backlight and all other parts are connected to 5V and GND through EXP1.
If you take out power from board, SD card and buttons lose their power. So there is no easy way to do that.
February 27, 2016 04:48AM
You could try this,
[forums.reprap.org]
He cuts the 5 volt wire of the usb cable, for another problem.
You will not be able to use the adapter for programming. But it should work
