Re: Piezoelectric disks for Z contact detect and bed levelling April 07, 2017 06:10PM |
dart16
OK... so I finally got around to fitting the piezo sensor to my mini kossel, replacing the servo operated optical sensor I had there for bed probing. Can I just say that you guys have the right approach as far as I am concerned... KISS. It works as described..no need to go digital or over complicate the thing.... it is perfect. If I can bludgeon a hole in the middle(ish) of a piezo sensor then anybody can... and it just works. Many thanks to Moriquendi for supplying the board I wouldn't be able to solder surface mount components any more (I can't see them for one thing!!) and ,thanks to everyone else for developing the design and for the ideas...I have re-gained 40mm by remounting the hotend up into the effector with the peizo mount...superb!!...Happy days!!!
ECJ
Yes! They are two distinct segments, each with its different challenges and results. It is not very pleasant to make comparisons and that is not the intention. I just came here to answer mentions that I would have copied the idea of DjDemonD. It was not my intention to advertise my product.
Re: Piezoelectric disks for Z contact detect and bed levelling April 07, 2017 06:20PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 07, 2017 06:22PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 07, 2017 06:30PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 07, 2017 07:03PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 08, 2017 03:01AM |
ECJ
DjDemonD
from the discussion about analogue electronics i.e. Leadinglights's, Moriquendi's and my implementation using an analogue PCB and ECJ's system using his digital microcontroller board. These are two separate but potentially confusing discussions.
Re: Piezoelectric disks for Z contact detect and bed levelling April 08, 2017 03:30AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 08, 2017 04:54AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 11, 2017 10:07AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 11, 2017 12:39PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 12, 2017 01:14PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 12, 2017 02:52PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 15, 2017 03:37PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 17, 2017 06:54AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 17, 2017 03:39PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 17, 2017 03:44PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 19, 2017 05:16PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 19, 2017 05:40PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 19, 2017 07:09PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 19, 2017 07:34PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 19, 2017 08:16PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 19, 2017 09:11PM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 02:33AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 04:06AM |
Moriquendi
I started on a kit with spring connectors like that and I've just bought my daughter one too, they still make them.
What are the advantages of very low contact pressure? I'd have thought that 1 gram or 10 grammes wouldn't matter provided it was consistent.
Idris
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 04:36AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 04:52AM |
nebbian
Thanks. Is there a higher resolution schematic available? That one is really hard to read.
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 04:59AM |
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 06:33AM |
leadinglights
In the past many people have given reasons why piezoelectric discs would not work, most of these reasons have been shown to be false but the claim that pushing a hot nozzle against the build surface is a bad thing has never been totally dismissed. On my Cartesian printer I have the amplifier set very insensitive to combat the shaking at the end of X and Y moves. The contact pressure was about 100 grams and the time the nozzle remained in contact with the bed was about 16ms. Examining the bed surface under a 40X microscope with oblique lighting there was a barely visible mark on blue tape but nothing on Kapton. Repeating on my Delta printer at 10 grams pressure there was nothing on any surface but when I set the pressure to 20 grams there was again a very faint mark on blue paper.
Since 10 grams is good, having a bit of wiggle room would be better. The target is 1 or 2 grams with 5 grams as a fallback position.
Mike
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 06:48AM |
ECJ
I do not understand why you care about this question of probing with the heated nozzle. Of course there is variation with heating, but I assume it's always the same. Here I do the probing with the cold nozzle and compensated with z offset and never had problems.
Is there really any plausible reason to probe with the heated nozzle? I wonder what it is.
Re: Piezoelectric disks for Z contact detect and bed levelling April 20, 2017 07:50AM |
