Why no affordable 32bit electronics March 05, 2016 08:43AM |
Re: Why no affordable 32bit electronics March 05, 2016 09:08AM |
Re: Why no affordable 32bit electronics March 05, 2016 11:35AM |
Re: Why no affordable 32bit electronics March 05, 2016 11:52AM |
the_digital_dentist
Improved reliability, additional features, and ease of use are worth a few extra $ to some people.
Re: Why no affordable 32bit electronics March 05, 2016 12:10PM |
the_digital_dentist
the_digital_dentist
And clearly not to others...
Re: Why no affordable 32bit electronics March 05, 2016 12:49PM |
Re: Why no affordable 32bit electronics March 05, 2016 01:02PM |
Re: Why no affordable 32bit electronics March 05, 2016 01:04PM |
Re: Why no affordable 32bit electronics March 05, 2016 01:19PM |
Frans@France
What would 32bits give you when not running graphical LCD or any LCD and not a delta? Not more speed as most 3d printers are not build good enough to run at 250mm/s, Also no need to go below 32 microsteps so that's also not a reason to have more power. So what is left?
Re: Why no affordable 32bit electronics March 05, 2016 01:28PM |
Re: Why no affordable 32bit electronics March 05, 2016 01:47PM |
Re: Why no affordable 32bit electronics March 05, 2016 01:51PM |
Frans@France
So why not the Gen7 32bits version that has just been released. Around Euro 48,- or cheaper if you do the pcb yourself. That would agree with the OP's question "Why hasn't a RAMPS-like system emerged around the $50 price point?"
EDIT : added link [forums.reprap.org]
Re: Why no affordable 32bit electronics March 05, 2016 02:11PM |
Might be that your definition of "very actively developed "is different then mineQuote
rmlrn
Gen7 looks nice but AFAIK it only runs the Teacup firmware which doesn't seem very actively developed compared to others like Smoothie.
You don't have to order from Europe as you can diy, but if that is not your cup of teaQuote
rmlrn
Also the only place to order from is in Europe, and only sells unassembled anyway?
Re: Why no affordable 32bit electronics March 05, 2016 02:31PM |
Re: Why no affordable 32bit electronics March 05, 2016 03:15PM |
Frans@France
rmlrn
rmlrn
Also the only place to order from is in Europe, and only sells unassembled anyway?(pun intended) then this board is indeed not what you are looking for.
If it must be a finished cheap product then you might have to wait until some volunteer is willing to take the risk, uses his/hers scare free time and throws his own hard earned money at a project like that.....however try to lookup on the ramps-fd history and see why that volunteer stopped doing it. Hint : it was not because of the board being (in your words) "flawed". That history and some others (jhead comes to mind) will maybe answer the "Why no affordable 32bit electronics" question.
Re: Why no affordable 32bit electronics March 05, 2016 04:58PM |
Admin Registered: 17 years ago Posts: 14,039 |
Re: Why no affordable 32bit electronics March 05, 2016 05:31PM |
Yes, and the reason for that is that the designer still was working on it, sharing so other could provide feedback and some Chinese manufactures looking to making a quick buck started selling this non finished design! Destroying in one simple move the reputation for a design that would have launch 3D into 32bits. The designer was so disgusted by this he stopped working on it and started\joined (together with others I believe) the RADDS, and was so kind to warn the world about the RAMPS-FD that those manufactures were selling. Just like some manufacturers are destroying E3D reputation and JHead, not only just by copying the design but by completely f..ing-up the resulting product.Quote
rmlrn
These aren't my words, "If you buy one, its better destination is a shelf for component reuse or a bin if you don't have the knowledge or will to modify it" is a quote from the giant warning paragraph that's the first thing on the RAMPS-FD wiki page.
Re: Why no affordable 32bit electronics March 05, 2016 07:49PM |
Re: Why no affordable 32bit electronics March 05, 2016 08:55PM |
Re: Why no affordable 32bit electronics March 05, 2016 09:36PM |
Re: Why no affordable 32bit electronics March 05, 2016 09:57PM |
Re: Why no affordable 32bit electronics March 05, 2016 11:23PM |
Re: Why no affordable 32bit electronics March 06, 2016 01:44AM |
Admin Registered: 14 years ago Posts: 7,217 |
Re: Why no affordable 32bit electronics March 06, 2016 02:32PM |
rmlrn
Also the only place to order [a Gen7] from is in Europe
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Why no affordable 32bit electronics March 06, 2016 07:40PM |
Re: Why no affordable 32bit electronics March 06, 2016 07:50PM |
MechaBits
Is Ramps not agnostic with regards to if it was being driven from 16 or 32bit arduino, what needs altering for it to work?
Re: Why no affordable 32bit electronics March 06, 2016 07:55PM |
Re: Why no affordable 32bit electronics March 06, 2016 08:23PM |
Re: Why no affordable 32bit electronics March 06, 2016 09:46PM |
Re: Why no affordable 32bit electronics March 07, 2016 02:10AM |
