Independent Safety / Fire detection system
Posted by RoundSparrow
November 18, 2007 01:18PM
Has there been any discussion on independent fire and safety systems? Given the slow printing speed of RepRap, I see might be pretty common to leave it unattended...
I'm thinking of some kind of independent monitoring system that watches the Extruder Head (maybe even hooked into the XYZ position data) and sounds an outside alarm or shuts down the ongoing work. It could also scan for general fire that may develop in the monitored data.
Goal is to catch overheating situations due to alpha or beta quality software, home made electronics, etc winking smiley Don't want a software crash to leave a heating element on and producing toxic plastic gases!
I really don't have the skills to design such electronics, but not going to keep me from starting research.
I found one project along the lines of what I'm thinking:
[www.appliancemagazine.com]
"Ultra-Low-Resolution Thermal Imaging for Detecting Kitchen Hazards"
VDX
Re: Independent Safety / Fire detection system
November 18, 2007 02:08PM
Hi RoundSparrow,
... there should be a security-check for overheating and/or the reprap shouldn't be used unadvised!
As i'm trying with laser-sintering and -cutting, i had some thoughts about removing the toxic gases too - for my testing i used a coal-absorber-filter and ventilated the fume through a tube in the garden winking smiley
When someone uses plastics or solvents, which exhaust toxic or even weak health-relevant gases (most heated plastics do!), then security-measures are a must!
When there is a chance for overheating the material, then too!
I dindn't know exactly, which IR-spectrum cheap web-cams have, but there is a fair chance, that with a good IR-trespassing filter there could be made a cheap IR-camera - maybe someone can look, which vendors have the 'deepest' IR-sensing camera-chips or we remove the IR-filters from normal ones and test ...
Viktor
Edited 1 time(s). Last edit at 11/18/2007 02:11PM by Viktor Dirks.
November 18, 2007 05:55PM
I just wrote a timer routine into mine that turns off the extruder barrel heater after about five minutes if the polymer pump isn't running. I seriously doubt that mine would ever heat up enough cause a fire problem. The bottom brass flange connected to the extruder barrel has never been above 125 and is usually down around 80. Not insulating the extruder barrel has its compensations. spinning smiley sticking its tongue out
November 18, 2007 10:50PM
Viktor, yha, I'm already playing with Linux IR cameras right now for another project (ZoneMinder). I was going to try that; but I also have a Fluke IR temp sensor (hand held) that would seem more ideal. Such a sensor on a motor tied to the host PC. In an ideal world, point it at the xyz coordinates of the extruder head and use it as a way to validate the information RepRap thinks is going on.
I consider this (scanning sensor) an overkill approach. But wanted to toss the topic onto the table.
November 19, 2007 03:12PM
a simple solution would be to mount a smoke alarm on your reprap machine.
if you wanted to take it further, it would be cool to wire the alarm circuit so that it triggered the machine to shut down as well as make its loud noises.
November 19, 2007 03:34PM
hmm but what happens if the pump snaps and rotates in the air without feeding any material...?
Do I really dare to have this thing running unattended in my home?
November 19, 2007 04:15PM
Depends on what you mean by "unattended". If you are talking about leaving it running while you were gone for the weekend, I'd say no. I have no problems leaving mine running while I take a nap. I don't leave it running overnight, though, unless I'm up. I'm well past the time where I have to hover over Tommelise.
November 20, 2007 02:07PM
i would not recommend it, yet. like forrest said, once you have it up and running for a while, its fairly safe. but right now, its still very much in the research stages.
once we get to the point where we've had many machines up and running for multiple hundreds of hours and have gotten more design refinements in it, i'd say yes (like, say fire detection and auto-shutdown). also, at some point in time we're going to *need* to do that, as the idea here is to create a human-free print process.
November 20, 2007 04:20PM
Can someone with more experience than I in electronics help me locate a place to order a reasonably priced "Thermopile array sensor" ($35 or under) that I could hook up to an Arduino? I will need step by steps on what parts I need to order winking smiley
Basically I want to be able to have something equal to my handheld Fluke IR temp sensor that I can start to play with (connected to a computer via Arduino).
