Layer cooling fan March 11, 2016 11:34PM |
Re: Radial fan March 12, 2016 01:46AM |
Re: Radial fan March 12, 2016 09:53AM |
Re: Radial fan March 12, 2016 02:18PM |
Re: Radial fan March 12, 2016 05:07PM |
Re: Radial fan March 12, 2016 05:21PM |
Re: Radial fan March 13, 2016 07:57AM |
Re: Radial fan March 13, 2016 10:26PM |
Re: Layer cooling fan March 14, 2016 12:24AM |
Re: Layer cooling fan March 14, 2016 03:20AM |
Re: Layer cooling fan March 14, 2016 07:59AM |
Re: Layer cooling fan March 14, 2016 10:44AM |
frankvdh
I recently switched from an axial to a radial filament cooling fan, and I'm very happy with the result... a huge improvement. Remember to only turn it on after the first layer is printed.
What duct do you have on it? I don't have any duct on mine (yet), and have it pointed vaguely at the nozzle tip, from about 30 degrees up. When then fan turns on, the hot-end temperature drops by about 5 degrees (which is why I want a duct on it).
Re: Layer cooling fan March 14, 2016 10:48AM |
JamesK
Yes, like most things with 3d printing it's not completely straight forward. You want to avoid the fan blowing on the hotend as it will drop the termperature pretty significantly if you're not careful. A fairly well directed jet of air targeted just below the nozzle is useful for bridging, but it's prone to being very dependent on which direction the nozzle is moving at any time. A more diffuse jet (ideally from all sides) does better at cooling an entire layer so that it is rigid before the next layer starts. Once you decide on a duct shape and position, you then have to tune the fan settings to get good results - a whole lot of trial and error. Losing some layer adhesion when you start using a fan is normal, so you need to increase the hotend temperature to compensate. It's all a balancing act.
I'm surprised you didn't see an improvement with overhangs and bridges though. With pla I was getting very noticeable improvements pretty much straight away, but I did go straight to a pair of ducted radials that were very close in to the nozzle. They're further back now (space issues under the carriage with a new extruder) and not working so well. At full speed they are noisy, I use a max of 70% during printing and only use 100% for post print cool down.
Re: Layer cooling fan March 14, 2016 01:17PM |
Re: Layer cooling fan March 15, 2016 06:38AM |
Re: Layer cooling fan March 15, 2016 07:50AM |
Re: Layer cooling fan March 15, 2016 08:11AM |
Re: Layer cooling fan March 15, 2016 09:01AM |
Re: Layer cooling fan March 15, 2016 01:15PM |
orictosh
Upon my Ormerod 2 I switched from the 40mm axial fan to 75mm x 35mm radial fan, which gave good results in cooling the print.
Also found this post about short layers (time needed to complete the first layer is too quick to provide a good base for the next, ends up looking like "Ice Cream" ) in which various fan duct and shrouds were tested. Also give links upon page to the STL files, which is good.
[www.desiquintans.com]
In slic3r's settings under the cooling you can disable the fan for the first or more layer
With overhangs curling up, up the print speed by 5 so 40 becomes 45 etc, also increase the temp, only if you started at the lower end of the manufactures stated temp range.
as I did 190 - 215. With good cooling I was able to set the temp at 205 and gravity kept the corners from lifting.
Re: Layer cooling fan March 15, 2016 11:52PM |
