Ideas for 1000mm^2 bed March 13, 2016 12:29AM |
Re: Ideas for 1000mm^2 bed March 13, 2016 08:17AM |
Re: Ideas for 1000mm^2 bed March 14, 2016 09:59PM |
Re: Ideas for 1000mm^2 bed March 14, 2016 10:37PM |
Re: Ideas for 1000mm^2 bed March 14, 2016 10:39PM |
L4nce0
I'm looking at [www.onlinemetals.com] I can order a MIC 6 plate 46inches ^2 (bed is just under 40 inches) at a quarter inch thickness, with shipping for like 600. These are casted plates with high precision! Maybe that's the solution? I was surprised I could order them so large and have delivery for just 60. (I mean I just paid UPS 100 to ship a broken b9 across country)
Thoughts? I mean, those are some BIG plates. I don't know what I'd do if I ever had to move. Also as I am living with family, I am pretty sure I am going to be murdered the day this arrives..
Re: Ideas for 1000mm^2 bed March 15, 2016 01:29AM |
Re: Ideas for 1000mm^2 bed March 15, 2016 09:37AM |
Re: Ideas for 1000mm^2 bed March 15, 2016 10:30AM |
Not going to help that issue. Pocketing the plate will cause more issue than help, even in cast. Plus you don't want to pay what it would cost to machineQuote
gmh39
Correct me if I'm wrong, but my gut tells me you could mill/drill holes throughout the plate to help counter the thermal expansion. You would need to do some thermal analysis to keep the holes as small as possible and figure out the best pattern, but it would give the the aluminum some "room to grow".
Re: Ideas for 1000mm^2 bed March 16, 2016 08:10AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 04:57AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 05:38AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 06:19AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 06:29AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 06:37AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 07:18AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 08:01AM |
Re: Ideas for 1000mm^2 bed March 18, 2016 09:28AM |
Re: Ideas for 1000mm^2 bed March 19, 2016 06:48AM |
That was my thought. however there is a stark advantage when you start thinking about Multiple printing arrays. That said I wont be going that route.Quote
the_digital_dentist
It looks like an interesting design. The main weakness I see is that as the print gets taller the largest portion of the XZ mass get higher and higher in the air and is going to swing like a pendulum every time it reverses direction. Unless you use very low acceleration which ultimately means printing very slowly, print quality will suffer toward the top of tall prints. If the X axis were supported by 3 or 4 Z "posts" spaced maybe 200-300 mm apart the mechanism would be stiffer (but heavier) and capable of more uniform print quality throughout tall prints.
Re: Ideas for 1000mm^2 bed March 19, 2016 08:51AM |
Yes, and I noticed that all the videos I have seen look to be using very moderate print speeds.Quote
Dentist
L4nce0
The shipping is pretty nasty! More than the cost of the pane.
