Yet another Prusa x axis waiting your comments March 13, 2016 10:21AM |
Re: Yet another Prusa x axis waiting your comments March 13, 2016 11:03AM |
Re: Yet another Prusa x axis waiting your comments March 13, 2016 11:39AM |
Re: Yet another Prusa x axis waiting your comments March 13, 2016 12:17PM |
Re: Yet another Prusa x axis waiting your comments March 13, 2016 12:38PM |
Re: Yet another Prusa x axis waiting your comments March 13, 2016 02:37PM |
Re: Yet another Prusa x axis waiting your comments March 14, 2016 08:30AM |
Re: Yet another Prusa x axis waiting your comments March 14, 2016 08:43AM |
Re: Yet another Prusa x axis waiting your comments April 19, 2016 04:48PM |
Re: Yet another Prusa x axis waiting your comments April 19, 2016 06:07PM |
the_digital_dentist
Well, thanks, but I am strictly an amateur. The first version of my machine was built starting from zero knowledge of 3D printers/machine design and very limited knowledge of machining techniques. The second version was just a redesign to fix all the things that bothered me about the first. Now I am slowly correcting minor things about the second design that bother me. I am rapidly running out of things to do to it so development/modifications will be ending soon (I hope) so I can move on to other projects (a coreXY machine with about 1m Z capacity and a chocolate printer).
Re: Yet another Prusa x axis waiting your comments April 19, 2016 06:34PM |
Re: Yet another Prusa x axis waiting your comments April 19, 2016 11:12PM |
Treito
How high is your printing speed? Because of the principle design of an I3 you can't reach very high speeds. I hope I can tune one of my printers to reach higher speeds until my own design will be ready.
Re: Yet another Prusa x axis waiting your comments April 20, 2016 12:36AM |
Re: Yet another Prusa x axis waiting your comments April 20, 2016 03:45AM |
the_digital_dentist
Treito
My Y axis is massive and driven by a ball screw, and the linear guides have some preload which increases stiction and friction. When I chose the motor I did so with a goal of 50 mm/sec print speed. The calculations said I needed about 380 oz-in torque for that, so I bought a 425 oz-in motor. The machine prints beautifully at 50 mm/sec. Since the original design, I have made some modifications that have reduced the mass in the Y axis by about 1 kg, so theoretically I should be able to print faster. I have not tested it any faster. Most of the time I print at 30-50 mm/sec.
Print speed is over-rated. Keep in mind that it's molten plastic coming out of the nozzle. Once it leaves the nozzle, it's out of your control. If you drive the machine super fast, you'll be flinging molten plastic all over the place and the the layer registration will be bad and the print will look terrible. I have seen many videos of people running machines at 200 mm/sec. They get the machine moving that fast but the prints look pretty bad, as expected. What's the point of that kind of speed if the print looks bad? I've printed very few objects where the print quality was less important than print speed.
If you want to print faster, you have to reduce moving mass. Reducing friction helps too. As you increase speed, starting and stopping the motor precisely becomes more difficult and prints start displaying artifacts. Increasing power supply voltage helps.
Re: Yet another Prusa x axis waiting your comments April 20, 2016 04:13AM |
Re: Yet another Prusa x axis waiting your comments April 20, 2016 04:21AM |
Slackdaddy
Are you mass producing the x carriage/extruder parts ?
Slack
Re: Yet another Prusa x axis waiting your comments April 20, 2016 06:13PM |
