I've persuaded work colleagues that we can use our new 3d printer to create the main parts for a second one.
http://www.3dcubicon.com/english/product/product_01.asp?gidx=56
I've picked the Snappy because it is the most printable of the Reprap models. We will use ABS/solid fill to print for max strength.
The Cubicon Single needs the STL files exported to Gcode files for printing.
Can I ask, are all the Snappy components printable without the need for generating support scaffolding? Some pieces appear to have areas that might need it. Or are they small enough for the printer to deal with (eg: it can pass over the small gaps without the print failing)?
Thanks in advance.
Jason.
