Moisture in ABS close up of the results
Posted by tmorris9
March 28, 2016 09:34PM
I was changing filament today and when I was flushing the old color out I noticed the new color felt rough so I thought I would show a photo for those that don't know that moisture can be a problem with ABS filament.
This is a 50X microscope view or silver ABS extruded with a .40mm nozzle. You can see all the pits in the surface and while this would print, it would not be a silky smooth print like I normally get.
Fix? Well I have a highly calibrated convection toaster oven I use to use for another purpose. I put the filament roll in it at around 65c for an hour or two and it will dry it out without melting it.
Re: Moisture in ABS close up of the results
March 28, 2016 11:28PM
wow, never seen that with the 60Kg of ABS I have run despite not always sealing part used rolls into airtight bags.
Curious what you general ambient humidity is?
March 28, 2016 11:44PM
Our humidity is around 50% most of the time. You cannot see the damage with the naked eye but the extrusion feels a bit rough. It takes a lot longer for it to affect ABS than PLA but it can.
March 28, 2016 11:57PM
2 hours of drying later.....
March 29, 2016 08:25AM
Nice before and after comparison - thanks!
