Search for using a mosfet with endstops, I think you can do it that way but I'm not very familiar with It. The other way is using a relay module, so get a relay module where the coil is switched at the voltage of your endstop signal eg 5v/12v whatever. I am assuming your endstop puts out 0v triggered and 5 or 12v open, so connect the endstop signal to the input on the relay, power the relay from your printer board. Then wire 5v to the com on the other side of the relay and send the NC output to your printer endstop signal pin.
When the endstop is open the relay will be closed so the NC output gives 0v. When the endstop is triggered the relay opens and the NC output gives 5v.
These modules have leds to show status and give a mechanical click when switching. There is a tiny delay in switching so don't set your homing feed rate too high.
Here is a 5v module [
pages.ebay.com] but 9v and 12v modules exist also.
