Print bed wire melted RAMPS board, what happened? April 09, 2016 03:01PM |
Re: Print bed wire melted RAMPS board, what happened? April 09, 2016 03:15PM |
Re: Print bed wire melted RAMPS board, what happened? April 09, 2016 04:53PM |
jinx
It could well be just a bad wiring moment , do you have a soldering iron, tin the ends of the wires, stop any stray threads. another culprit is the heatbed PID enabled but not configured.
Re: Print bed wire melted RAMPS board, what happened? April 09, 2016 04:54PM |
Re: Print bed wire melted RAMPS board, what happened? April 09, 2016 05:16PM |
cant say I had/have any issue with tinning the ends, but I aint using massive amounts of solder either, still their no excuse for not doing a proper job either which ferrules would you suggest for those ramps connector.Quote
DC42
Tinning the wire ends is bad advice and more or less guaranteed to cause problems.
Re: Print bed wire melted RAMPS board, what happened? April 09, 2016 07:06PM |
Re: Print bed wire melted RAMPS board, what happened? April 09, 2016 08:36PM |
Re: Print bed wire melted RAMPS board, what happened? April 09, 2016 08:48PM |
Re: Print bed wire melted RAMPS board, what happened? April 10, 2016 09:15AM |
Re: Print bed wire melted RAMPS board, what happened? April 10, 2016 03:44PM |
Re: Print bed wire melted RAMPS board, what happened? April 11, 2016 11:37AM |
Re: Print bed wire melted RAMPS board, what happened? April 11, 2016 01:23PM |
Re: Print bed wire melted RAMPS board, what happened? April 13, 2016 04:00PM |
JamesK
The simplest solution is to avoid taking the +V line for the heat bed through the ramps. It's only there to go through the poly fuse and to my mind the benefits don't merit the heating issues. I'd recommend getting an inline fuse (for example) and running a power line directly from the power supply, via the fuse, to the heatbed. Switching remains on the -V line on the ramps. Keep the -V connections from the psu to both connectors on the ramps, that helps distribute the return current over the pcb tracks and carry the current back to the psu. With this arrangement the ramps runs much cooler.
Re: Print bed wire melted RAMPS board, what happened? April 13, 2016 04:08PM |
Re: Print bed wire melted RAMPS board, what happened? April 13, 2016 04:42PM |
Re: Print bed wire melted RAMPS board, what happened? April 13, 2016 04:50PM |
Re: Print bed wire melted RAMPS board, what happened? April 13, 2016 04:57PM |
Re: Print bed wire melted RAMPS board, what happened? April 14, 2016 05:29PM |
Re: Print bed wire melted RAMPS board, what happened? April 14, 2016 06:19PM |
Re: Print bed wire melted RAMPS board, what happened? April 15, 2016 02:22AM |
Re: Print bed wire melted RAMPS board, what happened? April 15, 2016 06:17AM |
Re: Print bed wire melted RAMPS board, what happened? April 15, 2016 07:13AM |
