E3d titan extruder April 14, 2016 10:18PM |
Re: E3d titan extruder April 15, 2016 02:08AM |
Re: E3d titan extruder April 15, 2016 09:31AM |
Re: E3d titan extruder April 15, 2016 02:32PM |
Re: E3d titan extruder April 15, 2016 07:12PM |
Re: E3d titan extruder April 16, 2016 01:56AM |
Re: E3d titan extruder April 16, 2016 09:45AM |
ElmoC
I ordered one from E3D before Filastruder had them available. One thing I noticed with Filastruder is they don't have the motor listed as available. The extruder calls for a motor with a D shaft but all the listings I have found are the smooth shaft. I sent a message to Filastruder asking about the motor. Waiting to hear back from them.
UPDATE: Filastruder is not carrying the motors at this time.
Re: E3d titan extruder April 16, 2016 10:00AM |
JonS
Tom Sandladerer already has one that he's going to review, according to his latest video: Tom Sandladerer's Extruder/Hotend Video
Hopefully we won't have to wait too long for his review.
Re: E3d titan extruder April 16, 2016 11:26AM |
msaeger
ElmoC
Do you really need the D shaft or are they saying that because it would give a better grip on the grub screw? The hole in the gear looks round in their instructions.
Re: E3d titan extruder April 16, 2016 11:27AM |
dc42
I find a 3:1 gear ratio about right and that is what I use on both my printers. 5:1 is OK with short motors but not with long ones in my experience.
Re: E3d titan extruder April 16, 2016 03:59PM |
Re: E3d titan extruder April 16, 2016 04:18PM |
DjDemonD
dc42
What's the issue with long motors, too much inertia on retraction?
Re: E3d titan extruder April 16, 2016 04:52PM |
dc42
It's a matter of balancing torque vs. acceleration. It's quite common for the extruder nozzle to be temporarily obstructed, e.g. due to over-extrusion or curl-up of the previous layer
Re: E3d titan extruder April 16, 2016 05:14PM |
Re: E3d titan extruder April 16, 2016 05:50PM |
Mutley3D
dc42
Is this a theory or a fact backed up with evidence of the the recurring blockage?
How can molten plastic on the tip of a hotend heated to melting temperature cause a blockage? I would like to understand this more.
Re: E3d titan extruder April 16, 2016 06:14PM |
Re: E3d titan extruder April 16, 2016 06:22PM |
Re: E3d titan extruder April 16, 2016 06:28PM |
Re: E3d titan extruder April 16, 2016 06:36PM |
Re: E3d titan extruder April 16, 2016 06:50PM |
Re: E3d titan extruder April 16, 2016 07:25PM |
Unless it's a specialist disk for aluminium it will be worse by a lot than using a fine tooth tungsten carbide wood blade. It's easy to get them exact, just make a jig from some timber firstQuote
DjDemonD
I was planning to use a mitre saw and metal cutting disc but there is a precision engineering company near to me so I am tempted to have them cut a little more precisely, I also need the centre holes tapped to m6).
Re: E3d titan extruder April 16, 2016 07:33PM |
Re: E3d titan extruder April 17, 2016 12:25AM |
msaeger
JonS
Can't wait for that the sale ends Sunday :-)
Re: E3d titan extruder April 17, 2016 01:06AM |
JonS
msaeger
JonS
What sale?
Just buy one then and review it for everyone.
Re: E3d titan extruder April 18, 2016 05:44PM |
Re: E3d titan extruder April 18, 2016 06:37PM |
dc42
Using a 48mm long Nema 17 motor in a 5:1 geared extruder, I found that I had to set the motor current to about 400mA (compared to a rated current of 1.66A) in order to get reliable extrusion but not grind the filament when the nozzle is obstructed. However, that meant there was not enough torque to accelerate the motor as fast as I wanted during retraction. What I needed was a much shorter motor, run closer to its rated current to get the same torque, but with lower rotor inertia to get better acceleration at that torque.
Re: E3d titan extruder April 18, 2016 07:28PM |
Re: E3d titan extruder April 18, 2016 11:21PM |
Phytone
]I bought a Titan, fitted and working. Just went for the plain version, and bolted to my printer using a standard metal right angle for stepper motors (about 2mm thick).
Boxed item
[attachment 76668 IMG_2604.JPG]
Inside the box
[attachment 76669 IMG_2605.JPG]
[attachment 76670 IMG_2606_1.jpg]
Fitted
[attachment 76671 IMG_2609_1.jpg]
[attachment 76672 IMG_2610_1.jpg]
Quick print @ 100mm/s red flex
[attachment 76673 IMG_2611_1.jpg]
Goes together fairly well, but, the screw length is a bit off. The "short" bolts need a couple extra mm to bite onto my stepper motor, so Ive had to use the longer bolts and some nuts to take up the slack.
Will now tidy it up and tune the settings from stock.
Re: E3d titan extruder April 19, 2016 12:32AM |
